Poll
Are you using ReplayGain?
Yes, I am using new ReplayGain (EBU R128)
Yes, I am using old ReplayGain (Classic)
No, I am not using ReplayGain
Topic: Old vs. new ReplayGain (Read 3553 times) previous topic - next topic
In theory, both of them should be pretty equal, but in reality things are pretty different, especially with bass heavy music.
This poll is nothing special, I just want to see which one you like/prefer more.
gold plated toslink fan
Re: Old vs. new ReplayGain
ReplayGain (EBU R128) with the pre-amp set to -10dB and Album mode / apply gain is what I use for my entire music library.
I use the new because that is what my main version of Foobar has, it is faster and good enough to prevent large volume swings.
I don't use RG when listening to albums, I just, you know, adjust the volume :) but I do have some self-made compilations which are gathered from hundreds of various CDs, and when listening to these I use track-based RG.
But all my files do have RG info. New ones. Only thing I've noticed is that it is not that good if I turn on that "True peak scan", loudness can vary especially with dynamically highly compressed music. Without it, it's OK, didn't notice many differences. It does favor HF content, though :)
TAPE LOADING ERROR
That seems strange to me. I would think that dynamically compressed music usually gets highly negative RG and in such case True Peak shouldn't matter.
I use dsp "ReplayGain (alternative)" set at -14 LUFS. This is a different ReplayGain than the two you are referring to, right?
