Topic: AAC(16bit) vs WMA(24bit lossy).. Need some help and advice. (Read 2677 times) previous topic - next topic
We all know 24bit HiRes files are much more enjoyable than regular 16bit FLAC.
Bit depths matters. If it does not then 8bit FLAC files should perform as like 16 bit. Which is not. Even a 8bit FLAC provides poor quality than a regular 16bit AAC.
I need to convert 24bit (HiRes) FLAC to a lossy filetype.
I was using AAC (Qaac q127). Which is good If the source is 16bit FLAC.
But when I convert 24bit FLAC to AAC. I found a huge difference. The music losses its brightness, reverb, wideness & overall depth. Also some stereo instruments are not enjoyable anymore.
I don't know the technical stuffs of a codec but If a file loses it's bit depth. (Source 24 which cuts to Lossy 16).
Then It must lose the quality.
AAC provides 16bit audio quality.
But WMA Professional has 24bit.
So if my source is 24bit 96hz. and I convert it to AAC 16bit 44.1hz. The music will lose the quality.
But if my source is 24bit 96hz.. and I convert it to WMA 24bit 96hz. Which is still lossy I know but will the file have superior quality than AAC(which is 16bit)?
Re: AAC(16bit) vs WMA(24bit lossy).. Need some help and advice.
Seriously? You can immediately tell the difference?
Yes I can when I play those files on mobile which comes with Dolby Atmos.
But when I play those files on PC. I can't tell the difference because I don't have an external DAC attached to my PC.
And built-in realtek audio is not good enough.
We all do? I know they are not.
Yes, it matters, but only to a point. That point is at about 16 bits. That's why 8 bit does not perform as 16 bit, but that doesn't mean that 24 bit performs noticeably different from 16 bit.
Can you post some samples and ABX log proving that you can actually distinguish them? (You know, TOS 8 and all that :-) )
If you hear some difference, probably you're using some sketchy software that is applying effects in one case but not the other.  Try something reputable like foobar and they'll probably sound similar.
Lossy formats like AAC don't have a bit depth, so it is incorrect to say that they are 24 or 16 bit.  The concept simply does not apply.
WMA Pro is a dead format, so rather than waste your time with that I would troubleshoot whatever is wrong with your playback in the first place.  You mentioned a phone with Dolby Atmos, so probably all kinds of special effects being applied to your music.  Try without that and see if the problem goes away.
I would swear this topic looks like trolling.
The only advantage to 24 bit over 16 bit is it's harder to hear the noise floor, if you ever hear it at all... it doesn't really help fidelity otherwise. AAC and WMA are both lossy codecs that will limit bit precision to significantly reduce file size, but that part of the reduction is very transparent. What matters most is how good the encoder is.
LC-AAC was great for moderate bit rates for a while. But improvements with the best encoders haven't been made in years, especially for higher bit rates. With how things were left with the tunings, it's like you either have a lot of center channel spectra including noise substitution to satisfy listeners at moderate and lower bit rates and apparently satisfy spectrograms as well (since the Apple encoder retains a lot of inaudible high frequencies at 320 kbps) at the cost of some stereo fidelity, or you have somewhat better stereo fidelity at the cost of not retaining certain higher frequencies at all (like FDK or FhG).
384 kbps sounds like a good number for WMA. But have you tried FDK at 352 kbps?
I highly doubt that LC-AAC won't sound transparent at those high bitrates. I'm also skeptical that WMA Pro will perform better than LC-AAC.
