New update released in the beta thread.
@WarZard-X,
I've looked into it and %list_index% and %list_total% are not compatible with the playlist in this theme.
These are component specific fields that can be set in the playlist columns, i.e DUI/CUI columns for the native foobar playlist.
Not familiar with the WSH panel mod, but I guess it also had this function to support these...
From the foobar2000 wiki:
This section lists fields and functions which are specific to certain components. Unless otherwise stated, the fields and functions are only usable in the context of those components.
https://wiki.hydrogenaud.io/index.php?title=Foobar2000:Title_Formatting_Reference#Component-specific_fields_and_functions
If anyone knows an alternative, you can post it here.
Anyways, in the new beta just posted, you can hide the track numbers in top menu Options > Playlist > Track row
-TT
Line 5090. Use this.idx + 1, with a new pref. Reuse where necessary.
const track_num_tf = pref.showPlaylistIndexNumber ? this.idx + 1 : '$if2(%tracknumber%,$pad_right(' + (this.idx_in_header + 1) + ',2,0)).';
let track_num_query = track_num_tf;
if (this.is_playing) {
track_num_query = g_properties.show_header ? ' ' : track_num_tf;
Obviously I would add some kind of padding to the numbers, etc.
