Topic: Search-by-Distance-SMP (Read 19060 times) previous topic - next topic
Re: Search-by-Distance-SMP
Reply #150
Uhm... I could try playing with it, it's supposed you extract features with essentia and then you use some models within Gaia to analyze such features. Maybe it's possible to do it in 2 steps, yes.
Because waiting for an update in the windows cross-compiling is not working very well......  ;D
Reply #151
Definitely nope XD I would pay money for this.
Reply #152
https://github.com/regorxxx/Search-by-Distance-SMP/releases/tag/v4.2.0
[4.2.0] - 2023-03-04
Added
Changed
    UI: tweaked and unified buttons weight and margins, adjusted to scale set and DPI.
    UI: minor improvements to readme sub-folders names.
    UI: cursor now changes when over a button.
    UI: cursor now changes while performing buttons drag n' drop. It now clearly indicates when a move is allowed or it's outside the allowed range.
    UI: drag n' drop now only works when the mouse is over a button position. i.e. both the functionality and position rectangle are disabled if the mouse is not on a valid position. Previously moving the button to a blank part of the bar would have simply sent it to the first/last position for ex. This is disallowed now, which makes drag n' drop a bit more intuitive and offers an overall more cohesive experience. It also respects orientation and reflow settings.
    Internal code cleanup of menus.
Removed
Fixed
    UI: minor improvements to drag n drop behavior when mouse remains static and R. Click is released. Panel is redrawn immediately instead of waiting to move the mouse, current button remains hovered.
    UI: minor improvements to drag n drop behavior when R. Click menu is called in rapid succession. Panel is redrawn on the background now.
    Console: logging of null value not working properly (totally irrelevant except for debug purposes).
    Missing buttons' readme list.
Reply #153
https://github.com/regorxxx/Search-by-Distance-SMP/releases/tag/v4.4.0
v4.4.0 - Smart shuffle improvements
## [4.4.0] - 2023-05-08
### Added
- Smart shuffle: additional option to scatter instrumental, live and other tracks while respecting the smart pattern by Artist. For ex. if it can swap tracks without altering the Artist proportion for a given range of tracks, thus moving an instrumental track to another position to soft-limit the appearance of consecutive instrumental tracks. Same rationale applies for live tracks or other special conditions. This somewhat ensures any cluster of tracks is as diverse as possible.
- Smart shuffle: additional options to prioritize tracks by Rating, Play Count (original Spotify's behavior), Last played date, randomly...
- Tags: new menu entry on customizable button to edit raw JSON entry for every tag (in case advanced flags want to be edited, like combinations).
### Changed
- UI: additional info shown according to current settings on customizable button.
- Helpers: updated helpers.
- Console: multiple improvements when logging to file for FbMetadbHandle, FbMetadbHandleList, Error and unknown instances (totally irrelevant except for debug purposes).
- Console: menu entries are no longer logged to console after clicking.
- Descriptors: updated descriptors with multiple additions.
### Removed
### Fixed
- Tags: incorrect query parsing of multi-value tags, with combinations, if number of available values was lower than required.
- Tags: multi-value tags, with combinations (like MOOD), containing TF functions, were not using 'HAS' instead of 'IS' on queries to ensure multi-value tags are taken into consideration.
- UI: tooltip was not showing some settings forced by the current recipe and using the properties instead. Only affected the 'Method' line.
Reply #154
https://github.com/regorxxx/Search-by-Distance-SMP/releases/tag/v4.4.1
[4.4.1] - 2023-06-27
Added
Changed
    Buttons: after a query error, input box is shown again with last input to fix the error and retry.
    Remove duplicates: when removing duplicates, tracks left for comparison are now preferred by a configurable TF expression. By default higher rating and not live tracks is preferred. This is apart from the forced query filtering (which may result on this feature being irrelevant in some use cases). Delete '[foobar_profile]\js_data\presets\global\globQuery.json' and '[foobar_profile]\foobar2000\js_data\presets\global\globTags.json' files after installation.
Removed
Fixed
    Buttons: setting the forced query always returned 'Query returns zero items on current library.' error, for any query. Bug introduced on 4.0.0.
    Buttons: crash while editing a tag directly in JSON. Bug introduced on 4.4.0.
    UI: tooltip flickering while pressing Shift/Ctrl over a button in icon-only mode.
Reply #156
https://github.com/regorxxx/Search-by-Distance-SMP/releases/tag/v4.5.0
[4.5.0] - 2023-07-28
Added
    Selection manipulation\Shuffle: new sorting bias settings. Key (sorted from 12A to 1B), Key 6A centered (starting from 6A). Using these is like merging Harmonic Mix (consecutive tracks should have similar keys) and Smart Shuffle.
Changed
    Configuration: ALBUM ARTIST is now used instead of ARTIST by default (on new installations). This ensures better compatibility with classical music, where the artist is the actual performer but the album artist is the original composer/artist. To apply the change on existing installations, delete '[foobar_profile]\js_data\presets\global\globQuery.json' and '[foobar_profile]\foobar2000\js_data\presets\global\globTags.json' files. Further configuration may be needed via menus.
    Descriptors: updated descriptors with multiple additions and improvements for Folk and Progressive Rock music.
    Descriptors: improved debug checks for the genre/style graph.
Removed
Fixed
    Fix for non standard hyphen chars on path names.
Reply #157
https://github.com/regorxxx/Search-by-Distance-SMP/releases/tag/v4.6.0
[4.6.0] - 2023-09-20
Added
Changed
    Descriptors: updated descriptors with addition of 'Electrorock', 'Sephardic', 'Classical Sufi' and 'Electronic Sufi'. New 'Progressive Psychedelic Fusion XL' cluster.
Removed
Fixed
    HTML: fix broken rendering due to file path change.
    Cultural Regions: name replacers not being used at some stages of the code.
