Topic: [CUETools Database] What is the REL column? (Read 1993 times) previous topic - next topic
Hi.
I'd like to understand CUETools better. I am really a newbie, and I could not find that info.
I'd like to understand the infos on this page. I understand that all the releases in the bottom table have the exact same TOC and CRC32. But what is the REL column?
MOD Edit: Thread Title changed per TOS#6 (was "Newbie question" which did not properly describe the content of the thread).
Re: [CUETools Database] What is the REL column?
Relevance (fuzzy search results usually less than 100%).
You can find the "relevance" entries in the xml
http://db.cuetools.net/lookup2.php?version=3&ctdb=1&metadata=extensive&fuzzy=1&toc=0:16744:21799:35666:48599:64409:82686:92802:130374:146790:162048:188624:194122
So if there is no relevance number, means 100%. Right?
For MusicBrainz, the column is blank when a TOC based search results in a match (so not a fuzzy search)
For freedb the column is blank when only 100%.
korth
