Topic: foo_mpv - Video Player component based on mpv (Read 22286 times) previous topic - next topic
Re: foo_mpv - Video Player component based on mpv
Reply #125
Should be possible already - it's controlled by the foobar preference Display->Selection Viewers->Prefer currently playing track.
The behaviour should match the default UI album art UI element.
Reply #126
Thank you so much for the quick reply! Your example script got me on the right track.
One more question: I've managed to make the mpv window always display when opening foobar, by passing /command:"mpv" to foobar2000.exe. However, I can't get mpv to go fullscreen automatically. I tried adding various things to the mpv.conf, including fs=yes and window-maximized=yes, but neither seemed to work.
Is there something I can add to the config so foo_mpv always starts in fullscreen mode when launched?
Reply #127
Is it possible to dislay album art in mpv window if the art file has different name than "front"? Most of my files have names such as "name of the album front.jpg". Those do not show up as covers in mpv. They only show when I change file name to "front.jpg". Doing that would leave me with countless files of the same, indistinguishable name.
Reply #128
Is there an option to loop video with repeat (track) order?
When track ends it changes from video to album front cover. So I have to keep drag and drop video to mpv whenever track ends.
This is an awesome component I've been waiting for and I hope maybe suggestion or direction could be offer for me to do further investigation. Thank you a lot for your hard work.
Reply #129
The component handles fullscreening, as far as I remember it's not synced to mpv's idea of whether it's fullscreen.
If you use the popup only and not the UI components, it should be simple to make mpv go fullscreen immediately using a lua script that just has:
 mp.commandv("script-message", "foobar", "menu", "/View/mpv Commands/Toggle fullscreen")
The album art loading is handled by foobar not the component, you can change how it finds files in the preferences.
Ahh this is a bug, I didn't think about this usage. I'll make a note to fix it. In the meantime I don't think there is a workaround.
Reply #130
However, for MKV files, if you are using foobar's native MKV decoder, you can switch the audio track by right clicking on a file, Utilities->Select stream.
Actually, this works with foo_input_ffmpeg too and not only for mkv.
When I "select stream", a pop up window shows nothing, no one "stream", what should I do?
I have ffmpeg component instaled and I can't watch .flv and some .mp4 videos...
Reply #131
Below, some pictures for better explain my above post.
Thanks in advance.
Reply #132
Last time I tried foobar2000 itself would apparently refuse files with no audio stream. Am I right?
Reply #133
MPC-BE and Windows' "Movie & TV" can play the above video files fine.
I just would like to play in foobar2000 because is the only player I like to use...
Reply #134
I don't disagree.
Rather my point is that this might be a "foobar2000 wishlist item" rather than a "foo_mpv wishlist item".
Apparently, foobar2000 rejects the file and does not pass it to foo_mpv.
Annoying as it might be, it is kinda consistent with how an "audio-only" player would work. If it tolerates a file with 1 hour of video and 1 second of audio, it would probably play the audio and move on to the next file, eh?
Reply #135
@sammoth
thank for your nice Plugin, is it posible to activate i or shift+i for overlay displaying statistics about the currently playing file?
greetings
Reply #136
If you insert:
Shift+i script-binding stats/display-stats
into the input.conf page in the preferences on a new line, then while in fullscreen mode or while the video player popup is open, pressing shift+i will show the mpv info. There isn't any way to have this shortcut work from the rest of foobar though, ie. when not in fullscreen or with the popup open.
