Topic: foo_out_pulse - pulseaudio output (Read 14138 times) previous topic - next topic
Re: foo_out_pulse - pulseaudio output
Reply #50
Here you go, this is your patch on top of git master.
For reference, I built this on Arch as follows (after installing mingw-w64 and some libraries, configure (ie. bootstrap.sh) tells you which ones you need if they're missing):
./bootstrap.sh --host=i686-w64-mingw32 --enable-shared --disable-static --disable-waveout --disable-orc
make -j16 LDFLAGS='-shared'
cp ./src/.libs/libpulsecommon-13.99.dll ./src/.libs/libpulse-0.dll ~/desktop/pa
cp /usr/i686-w64-mingw32/bin/{libFLAC-8.dll,libgcc_s_dw2-1.dll,libintl-8.dll,libiconv-2.dll,libogg-0.dll,libsndfile-1.dll,libssp-0.dll,libvorbis-0.dll,libvorbisenc-2.dll,libwinpthread-1.dll} ~/desktop/pa/
Reply #51
Thanks.  Would you mind reporting what output you get with this build?
Reply #52
When playing something, I just get
load() function, cookie filename: C:\users\sam\.config\pulse\cookie
About to call pa_open_cloexec()
About to call pa_lock_fd()
About to call pa_loop_read()
Reply #53
load() function, cookie filename: C:\users\dave\.config\pulse\cookie
0134:warn:ntdll:FILE_CreateFile L"\\??\\C:\\users\\dave\\.config\\pulse" not found (c0000035)
Failed to read cookie file 'C:\users\dave\.config\pulse\cookie': Unknown error 10009
load() function, cookie filename: C:\users\dave\.pulse-cookie
0134:warn:ntdll:FILE_CreateFile L"\\??\\C:\\users\\dave" not found (c0000035)
So essentially the same as yours, right up to the point where pa_loop_read() fails, and it moves on to the next location.  (I assume you fixed the bug in my patch that didn't open a block for the 'else' further up.)  Anyway, I'll continue to investigate.
Reply #54
I can't make much sense of this.  One way or another, pa_open_cloexec() would be making at least one open() call.  Yet, no syscall shows up in the strace.  I can see that happening if there was a problem with the path conversion, for example.  But, surely, it would return a negative value in that case.  If wine swallowed the open() call and returned a negative value, I would get an additional message from load() in the log.  It's like wine is declining to pass on the open() call, while also reporting success.  As you can imagine, it's a challenge to search the wine bug database for a common word like "open".  I'll try to update wine sometime soon and try again.  What version are you running @sammoth?
Reply #55
I'm using wine staging 5.18 at the moment, but it was working on some previous versions and non-staging too.
edit: have you tried looking at wine's full debug log output? WINEDEBUG=+all
it's pretty verbose though...
Reply #56
"Pretty verbose" is understating it. :)  Yes, I had let it run for something like 30 mins and the fb2k window never appeared.  All the while it was creating a log file in the hundreds of MB.  Then I killed it.
Reply #57
I upgraded to wine-vanilla-5.18, and now it's working.  :D   I didn't think it was working at first, until I discovered that I needed to update the symlinks for both 'wine' AND 'wine-vanilla', the latter of which still pointed to 5.0.1 and was used by Dolphin by default.  D'oh!
Before the upgrade, I did actually get a WINEDEBUG=+all log.  I started by making a copy of fb2k and stripped it down to the bare minimum - simplest DUI, one playlist with one local file, no library, nothing but standard components and foo_out_pulse.  Then I could get a +all log in a minute or two.  Without getting into the dirty details, it went like this.  pa_read() called recv(), which rightly failed.  The subsequent WSAGetLastError() call returned 0x2719, which corresponds to WSAEBADF, instead of the WSAENOTSOCK error that the pulseaudio code was expecting.  That lead me to the following commit to Wine on 2020-07-27, which changed the translation of STATUS_INVALID_HANDLE from WSAEBADF to WSAENOTSOCK.
https://source.winehq.org/git/wine.git/commitdiff/587732acb7834a52a2af5bb45e59899ab8ec3f5d
The following appears in the release notes of the next version after, 5.14.
Alistair Leslie-Hughes (1):
      ws2_32: Correct returned error code for an invalid socket.
In conclusion, at last as far as wine-vanilla is concerned, a minimum of version 5.14 is required.  I don't think it made it into the 5.0.2 stable release that came a little later.  I don't see a patch for this in wine-staging immediately prior to 5.14, either.
Reply #58
Oh nice work! I will make a note of it on the readme.
Reply #59
Is anyone using this with pipewire-pulse?
Pipewire wiki says enabling the port in pipewire-pulse.conf is equivalent to loading module-native-protocol-tcp
context.modules = [
    {   name = libpipewire-module-protocol-pulse
        args = {
    # the addresses this server listens on
            server.address = [
                "unix:native"
"tcp:4713"
"tcp:127.0.0.1"
Seems to work
$ PULSE_SERVER=tcp:127.0.0.1 pactl info
Server String: tcp:127.0.0.1
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: no
Client Index: 118
Tile Size: 65472
Server Name: PulseAudio (on PipeWire 0.3.34)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.usb-Topping_D10-00.iec958-stereo
Default Source: easyeffects_source
Cookie: 74a4:5356
Playback in foobar2000 starts fine but if I seek through a track it halts. Any ideas?
Reply #60
Problem solved. Cause turned out to be PULSE_LATENCY_MSEC environment variable in my launcher script.
There is a noticeable (0.5sec~) latency while seeking now though, I don't remember that being an issue with pulseaudio. I hope one day foobar2000 can communicate with pipewire directly.
