Topic: Configurations Files (*.cfg) (Read 741 times) previous topic - next topic
Hello.
Is it safe to delete the *.cfg configuration files?
I would like to "wipe" the portable installation because there are many configurations that relate to components that have already been removed.
Thanks in advance.
Re: Configurations Files (*.cfg)
Yes it's safe to delete the *.cfg file in foobar2000/configuration if it belongs to a plugin you have already removed.  The only reason you might choose to keep it is if you intend to re-install that plugin again and intend to keep the same settings it had before.
Very clear. Thank you very much!
