Topic: exhale - Open Source USAC encoder (Read 331143 times) previous topic - next topic
Re: exhale - Open Source USAC encoder
Reply #1101
Yeah but that is SBR frequencies... not the same thing
the distortion I'm hearing is below the SBR frequency range
Also, oof, that 15khz tone sounds really quiet.. my ears suck.. in my right ear above 12.75khz volume starts dropping pretty quick and in my left ear 13.25khz
Reply #1102
Hey,
Does anyone know of a way to view the spectrogram of xHE-AAC tracks?
Audition, Audacity, and Spek do not support it.
Reply #1103
Convert your xHE-AAC audio files to wav.
EZ CD Audio Converter
Reply #1104
Thanks for the tip soundping. That works.
Reply #1105
I just committed a small change to exhale's CVBR modes f, g, and 5, 6, see https://gitlab.com/ecodis/exhale. The primary purpose is to remove some old macro-encapsulation code and to bring the average encoding bit-rates of those modes closer to the target rates (96, 108, 128, and 144 kbps, respectively, for stereo). Thanks very much to guruboolez for thorough checking of the encoding bit-rates, and for sharing the results in his public table. Encoding at the other modes hasn't changed at all since release 1.1.9.
Literally, this is a 1.1.9.2 sub-release, but you can also call it an exhale 1.2.0 beta release since I'll tag a final 1.2.0 release at the end of the year and the encoding results probably won't change anymore.
Chris
Reply #1109
the contents of 'version.h' in the code remain unchanged although the changes referred to above are implemented. Not really within my remit to change the version number. ;)
Reply #1110
Yeah, I was still trying some speedups when I committed this, which I finished today. So here's a new commit with updated 'version.h' for an official exhale 1.2.0 release candidate, including several code improvements (thanks again, jprjr and NetRanger!).
Changes since exhale 1.1.9, released one year ago:
  • C API correction, some code sanitizing (issue #24, merge requests !8!11, J. Regan)
  • exhaleLib: code cleanup, very minor quality improvements in CVBR modes f and 5
  • exhaleLib: 5% speedup of all modes, better target rate matching in CVBR mode g
More speedup might be possible with Visual Studio compiles (see macro SFB_QUANT_SSE in lib/quantization.h), but that's probably still suboptimal.
Please compile and test as usual.
Chris
Reply #1111
Errors when compiling from macOS:
/Users/christian/Downloads/exhale-master/src/lib/../../src/lib/quantization.cpp:13:5: error: macro expansion producing 'defined' has undefined behavior [-Werror,-Wexpansion-to-defined]
#if SFB_QUANT_SSE
/Users/christian/Downloads/exhale-master/src/lib/../../src/lib/quantization.h:29:29: note: expanded from macro 'SFB_QUANT_SSE'
#define SFB_QUANT_SSE (0 && defined (_MSC_VER))
/Users/christian/Downloads/exhale-master/src/lib/../../src/lib/quantization.cpp:49:5: error: macro expansion producing 'defined' has undefined behavior [-Werror,-Wexpansion-to-defined]
#if SFB_QUANT_SSE
/Users/christian/Downloads/exhale-master/src/lib/../../src/lib/quantization.cpp:226:6: error: macro expansion producing 'defined' has undefined behavior [-Werror,-Wexpansion-to-defined]
# if SFB_QUANT_SSE
/Users/christian/Downloads/exhale-master/src/lib/../../src/lib/quantization.cpp:283:12: error: variable 'tempBitCount' set but not used [-Werror,-Wunused-but-set-variable]
  unsigned tempBitCount, tuple, is;
4 errors generated.
make[1]: *** [../../build/quantization.r.o] Error 1
make: *** [release] Error 2
Reply #1112
Version 1.2RC (ARM, built on Oct 24 2022) compile without errors on Linux (64bit).
Reply #1114
The latest revision (46ae72aa) is compiled without errors even on macOS.
Reply #1116
NetRanger is the goat, thank you for your builds!
Opus VBR 256 + SoX
Reply #1118
exhale v1.1.9.1-4ef4bc3c
Built on June 30, 2022, GCC 12.1.0
with this build and preset 9 output files have avg bitrate ~128 kbps.
Argh, thanks for reminding me about this. This still happens with NetRanger's GCC compile of the 1.2.0 release candidate, so two things to mention here:
  • Please do not use NetRanger's GCC 12.2.0 compile since that still has the high-bit-rate issue reported here! Use his CLANG 15.0.3 binaries or John's Intel 2022 binaries instead.
  • I submitted a corresponding issue #26 on GitLab, summarizing the issue and asking for help. Again, experts on this wanted since I don't work with GCC/Msys2 myself, only VS.
For the record: The last known good GCC compile for the Windows platform here on HA is this one (exhale 1.1.9, compiled with GCC 11.2.0).
Chris
Reply #1119
I mean, since this is a known ongoing issue, perhaps @NetRanger should just not publish GCC builds of exhale until it's resolved?
Reply #1120
Can you please try again with the latest revision?
version 1.2RC (x64, built on Oct 24 2022) compile without errors on macOS Ventura 13.0 (64bit).
Apple clang version 14.0.0 (clang-1400.0.29.102)
Target: x86_64-apple-darwin22.1.0
Reply #1121
Thanks very much for the info, celona!
It seems it's been resolved very quickly on GitLab, thanks for C. Degawa. And NetRanger's compiles are always appreciated to identify such issues. Strange "signed/unsigned" interplay between GCC and MSYS2 was the cause, it seems, and not really exhale's fault, but oh well, rewrote one line of code anyway. NetRanger, feel free to give it another try with GCC 12.2.0 and the new revision.
(Note to myself:: don't forget to mention the fix of issue #26 in the release notes before tagging the final 1.2.0 release!)
Chris
Reply #1123
Tested the newly compiled GCC exhale binary on a few files now and it looks fine. Rather big change after the latest commit.
Great work on the quick fix. :)
