Topic: exhale - Open Source USAC encoder (Read 326574 times) previous topic - next topic
Re: exhale - Open Source USAC encoder
Reply #1175
Note that the main page of that MPEG-H decoder states that it supports only baseline MPEG-H level 4 profile. But I just gave it a super quick test, it refuses all non-MPEG-H files in its transport decoder. The binary is also 11% smaller suggesting it's missing a lot of stuff.
Reply #1176
Oh,  sorry for wasting your time!
It should have been better if they just made it as a superset of FDK-AAC decoder when it's apparently using the same code base.
Reply #1177
Hi... After marvelling with Carl's xHE-AAC exhale,
Anyone knows where I can find a Dolby AC4 implementation? My UHD TV includes this codec and I would like to use It.
Reply #1178
I took a quick look at exhale sources and I don't see it doing anything to source WAV file channel order. If that's the case @john33 is absolutely correct and multichannel files encoded with it are quite broken, unless manually reordered to correct channel order.
My apologies, you're absolutely right, I totally misunderstood how the extensible WAVE format works regarding multichannel (I thought it allows to reorder the channels... which it doesn't). Just committed a fix to exhale's main branch, along with a minor tuning for the low-rate BA_MORE_CBR modes. With that the channel ordering should be correct.
Chris
Reply #1179
New compiles on RareWares. :)
Reply #1180
tested
exhale-v1.2.1-14cdd94f-20250527_x64 -> broken return to prompt (i7-2600k) when encoding
exhale-v1.2.1-14cdd94f-20250527_x86 -> encode ok, preset 9, but foobar don't play it -> Unable to open item for playback (Unsupported audio track format)
mka encapsulation of the m4a same playback problem unsupported audio
Reply #1181
Apologies, I uploaded an AVX2 optimised compile in error for the x64 version. I'll recompile and upload again. Thanks for letting me know.
Playback requires this component in foobar (for 64 bit Windows, otherwise the standard component):
https://foobar.hyv.fi/foo_pd_aac.fb2k-component
Playback of encoded files with both encoders works fine here.
EDIT: x64 compiles now updated.
Reply #1182
1 out of 1 files converted with major problems.
Source: "Z:\EAC3.eac3"
  An error occurred while writing to file (The encoder has terminated prematurely with code -1 (0xFFFFFFFF); please re-check parameters) : "Z:\EAC3_5.1.m4a"
  Additional information:
  Encoder stream format: 48000Hz / 6ch / 32bps floating-point
  Command line: exhale.exe 9 "E318910B-98D2-4B18-9246-8C241372BAA3.m4a"
  Working folder: Z:\Temp\foo_converter\
  Conversion failed: The encoder has terminated prematurely with code -1 (0xFFFFFFFF); please re-check parameters
Reply #1184
Where does "exhale channel remap" come from? It's not required and I've never seen it before. And, the previous version would encode multichannel audio but the channels were not necessarily in the correct order.
Reply #1185
exhale... 1 out of 1 files converted with major problems.
John is right, Case's Exhale Channel Remap isn't required with the new version from today. Please don't use it anymore.
If the error still occurs when you don't use the channel remapping DSP, then please post the original input WAV file since it seems to have an unexpected channel map.
Chris
Reply #1186
Without using "exhale channel remap", the error still exists.
The original multi-channel music file comes from https://samples.ffmpeg.org/, and foobar2000 plays it normally without any problems.
Reply #1187
I already tested it with 6_Channel_ID.wav and it encodes and plays perfectly. What OS are you using? MSVCRT.dll may require updating.
Reply #1188
The updated exhale rejects at least side channels, not related to dlls.
Reply #1189
Ah, OK, I should check the code before commenting, I guess!  :(
Reply #1190
This has nothing to do with the runtime dlls, the problem should be the incorrect recognition of the multi-channel layout.
Reply #1191
Thanks, you two. Hopefully fixed in commit a6193fab ("fab" for "fabulous version" ;) ). Please give it another try.
Chris
Reply #1192
My 5.1 test signal now worked. A 3.1 channel test file with channels (FL FR FC LFE) was accepted but it plays back as 4 channel file (FL FR SL SR).
