Topic: search query and multi values tags (Read 794 times) previous topic - next topic
I've got an issue related to search query and multi values tags.
I'm searching in my whole library the tracks by an artist simply named "bob".
I could do this query %artist% IS bob
but then it won't return the tracks tagged with multi values, like "bob; nirvana"
In order to include the tracks tagged with multiple artists, I could do
%artist% HAS bob
but then it will return all tracks with bob inside their artist name, like bob dylan, and not all tracks by the artist simply named "bob".
Does someone there have an idea? Thanks!
Re: search query and multi values tags
Hi there,
Can you test for each individual multi-value  -
"$meta(artist,0)" IS bob OR "$meta(artist,1)" IS bob OR "$meta(artist,2)" IS bob
... And so on, etc, to cover how many multi-values are likely in your library.
(You can test how many values with $meta_num(artist) but I'm not sure it would be necessary, since if any are missing, they would not return results anyway)
Cheers
Thanks! It work fine :)
It's slower though, it's the bad side of multivalues tag, once you try to handle them
What are you trying to achieve with the search query in the end?
If it's not for an autoplaylist query or something similar, you could install either Facets or Columns UI (Filter panel) components which can break down the multivalue tags into simple lists automatically. There you could select bob and it would return all corresponding tracks for further use without having to worry about placement within the multivalue tag.
It's a query used in a spider monkey panel script, so it's specific to my code/layout.
Not sure if this would work any faster??
let has = fb.GetQueryItems(fb.GetLibraryItems(), 'artist HAS bob');
let is = fb.GetQueryItems(has, '"$meta(artist,0)" IS bob OR "$meta(artist,1)" IS bob OR "$meta(artist,2)" IS bob');
How about this?
"*$meta_sep(artist,*)*" HAS *bob*
I'm late
