Topic: Can't do custom sort (Read 1534 times) previous topic - next topic
I have a problem on sorting all of sudden. It supposes working fine in Win 7 before.
I can't remember if it doesnt work since I upgrade to Win 10.
Anyway this is the old script that I used: $if(%rating%,$repeat(●,%rating%)$repeat(o,$sub(5,%rating%)),ooooo)
The list wont change no matter I sort it up and down. I tried to make it as %rating% and it displays as "?" instead of number.
I assume the software cannot detect that field for some reasons. The rating number is stored correctly in the profile tho.
Any help is appreciated
Re: Can't do custom sort
Hi there,
The code works fine for me. Did you install Playback Statistics? If so, see the note here. If ratings are stored in file tags, you must use $meta(rating) to get them instead of %rating%.
Cheers
Hi there,
Cheers
I didnt install Playback Statistics, do I have to install it if I use Win 10? I pretty sure I didnt install it back in Win 7.
The rating which I said is the custom field which I created. So it likes:
Track Number
Total Tracks
Disc Number
Comment
<RATING>
The value is there but the software cant detect it. Any ideas?
Not sure, %rating% should work correctly without Playback Statistics. Can you check Preferences > Components list to confirm it is not there?
Where you are entering the script in your first post? Can you post a screenshot? (You can attach pictures to your post on these forums)
Can you create some custom playlist columns with the codes anamorphic gave you already and tell us what they return on your tracks?
$meta(rating)
%rating%
Track Number
Total Tracks
Disc Number
Comment
<RATING>
Could it be you lost your standard fields settings in the upgrade? Preferences > Advanced > Properties dialog > Standard fields: is the custom "rating" field listed?
I'm late
Oh I actually have Playback Statistic installed :P
I enter my script here
Error
Tried to make it simple
Looks like it cant detect the value
Properties
Any ideas?
hmmm I cant see this option under Advanced
Thanks guys! It works now :)
Since when do we need to use meta()? I pretty sure I haven't use this before.
