Topic: which low bitrate codec?? (Read 3732 times) previous topic - next topic
apart from ogg, what other low bitrate codec are there that could complate with it??
aac, mp3pro, mp3 plusV ... they are probably a bit worse than OGG tho
What is low bitrate?
300 bps
1200 bps
9600 bps
24 kbps
64 kbps
128 kbps
The answer is different for these data rates.
What gadget should do the the decoding?
PC
portable
--  Frank Klemm
1200 kbps
can be quite a low bitrate considering multichanel, 192KHz sampling, 24/32 bit etc. ...?
if you needvoice only you cna try acelpt.net acm codec
very good for 8 and 16kbits
Sven Bent - Denmark
what i mean is 64kbps.....
is ogg still the best?? aren't there any orternatives??
NO, not now and certainly not after the release of RC4
