Topic: 1.5b9 Last column in playlist don't display correctly after random startup (Read 782 times) previous topic - next topic
After random startup (or just after restoring foobar from system tray) last column in playlist viewer would not display correctly (kbps in my case) even there is enough column space. Sometimes it would also occur after resuming windows from hibernation while foobar is minimized at system tray (not sure if it is windows related but just to mention).
As far as I remember it didn't occur before beta 8.
foobar2000 plays music
Re: 1.5b9 Last column in playlist don't display correctly after random startup
Thanks for the bug report.
What formatting pattern does the offending column use?
Can you export the theme layout (Preferences / Default UI / Export Theme / just main layout) and upload the .fth file?
Happened again today at first foobar startup. (attached image)
Pattern is: %codec% | %bitrate% kbps
Alignment: Left
Uploaded.
Problem recreated, thanks for reporting.
