Topic: Replaygain calculation differs from winamp/flac (Read 1116 times) previous topic - next topic
Computed replaygain with FLAC, and with WINAMP and both gives almost same results (usually with less than 0.02db difference). But Foobar results are more than 10% off the ¿correct? value. Is there a way to calculate value as FLAC does?
Re: Replaygain calculation differs from winamp/flac
foobar2000 has been using libebur128 since version 1.1.6 (~2011). I think FLAC and Winamp use the original ReplayGain (by 2Bdecided).
You can try replacing the newer foo_rgscan.dll with an older version (e.g. foobar2000 1.1.5), but this might cause issues... not sure.
Or just use a portable 1.1.5 "installation" for your original ReplayGain scanning.
| QAAC ~ 192 kbps |
You can try replacing the newer foo_rgscan.dll with an older version (e.g. foobar2000 1.1.5), ...
That did the trick. Any idea why they changed calculation method?
It's more accurate according to the 1.1.6 changelog:
ReplayGain scanner now uses libebur128 for improved accuracy.
| QAAC ~ 192 kbps |
If you search this forum (use Google) you can find some discussion on whether EBU R128 was indeed an improvement over original ReplayGain. YMMV depending on material.
