Topic: selected files parameter  (Read 964 times) previous topic - next topic
Hello
How do I pass selected files as argument to external program. (for using in services)
the following command send only one file path, not all selected files.
C:\converter.exe  "%path%"
Re: selected files parameter
Try the foo_run_group plugin as mentioned at the post here:  https://hydrogenaud.io/index.php/topic,45223.msg955257.html#msg955257
The newest version is 1.02, not the one attached to the above post.  It's at a Japanese website;  first, go here:
https://ux.getuploader.com/foobar2000/download/215
Then, click inside inside the box centered below the MD5 box under the paragraph of text below that, which will begin the download:
