Topic: How to stop Foobar 2000 from starting minimized? (Read 165 times) previous topic - next topic
I use Foobar2000 pretty frequently, but I've noticed that if I close the program while it is minimized and then start it back up later, it will start minimized (the way it was when I closed it).  Although this may be desirable for some, I do not want this behavior; regardless of how I closed Foobar, minimized or not, I would prefer to always be able to see the Window whenever I start it up.
Supposedly there is a "Remember window position" option somewhere, but I cannot find it to save my life.  Can somebody help me figure out what I need to change to get the behavior I want, and where exactly I need to go to change it?  Thanks.
For reference, I am using Foobar2000 version 1.4.
Re: How to stop Foobar 2000 from starting minimized?
Hi there,
You could try modifying the Windows shortcut used on startup -
foobar2000.exe /show
(I use it with the opposite /hide to always minimize)
Incidentally, once upon a time you could set the 'Run' box in the Shortcut Properties > Shortcut tab, but I notice Windows 10 likes to ignore that setting. ::)
Cheers ;)
That will work, thank you very much!
In Preferences > Playback > Other, the first checkbox is Save playback state when closing foobar2000 and resume on next startup. That may be what you were looking for.
