Topic: Best earphones for Death Metal (Read 3346 times) previous topic - next topic
Hi folks,
I will keep it short.
I am in need of new, HQ Earphones, especially for the genre of (technical) Death Metal.
As always I have all my music stored in lossless and I want to make use of it.
Atm I am using Sennheiser CX300 II in-ears, but they aren't made for lossless.
Does anyone have a good tip for me, which ones to buy?
Regards,
Telepath
Re: Best earphones for Death Metal
What do you mean, headphones aren't made for lossless? Headphones are headphones, either they are good or bad sounding, they don't give a rat's ass what you feed to them.
What did you use before, if you are not satisfied with the current ones? What is the problem with the current ones?
Error 404; signature server not available.
Because some headphones have "bass boosted", "ideal for this and this genre" or whatever in their description.
Too much bass is deadly for metal at all because you only hear wrrrrrr.
They are sounding bad.
I don't hear a difference between mp3 and flac with them.
The headphones are 24.99 bucks hardware piece.
I used to have Teufel headphones they were way better.
But I want to have even better ones to unlock full capabilities of lossless audio.
Lossless music is nothing with cheap or crappy hardware like devices, headphones etc.
My actual end device for portable music listening is a Samsung Galaxy S8 in combo with the Sennheiser CX300 II.
It's a pretty cheap equipment, but I did as much as I can to get the best out of it, like magisk audio mods, kernel editing etc.
So I even need better earphones and asked for help.
You may want to rethink your understanding of audio codecs or be a little more exact in your statements.
In addition to smaller file size, a main point of mp3 is that there is a bit rate in which it is indistinguishable from lossy.
Not hearing a difference between Flac and Mp3 [at some encoded bit rate which differs across people] is expected outcome.
It is not a sign that some piece of hardware is faulty.
OTOH, if your preference is for less bass, certainly differing headphones have differing frequency responses.
OR, you could save cash and use an equalizer.
Explain please?
You aren't supposed to, anyway. At least if you are listening with level matching so that the mp3 version doesn't get clipped after decoding. And if the mp3 is encoded from the same source, with recent LAME version, by someone who isn't trying their best to fail at this simple task.
Either way, try something like audiotechnica ath-m50, they are (in my experience) producing neutral sound with no audible distortion (unless you go for really painful loudness levels) and only a little of bass amplification which is actually a good thing if you ask me (I still had to turn up the bass when I used them).
AFAIK everyone who tried these agreed that they sound accurate and work for everything.
There's no such problem; if you only hear wrrrrr it's probably because of nonlinear distortion?
I listened to all kinds of metal including "extreme" and "rough" varieties like Venom, Dissection, Deicide, early Sepultura, Bethlehem, Elysian Blaze, etc. etc. with increased levels of bass and everything was 100% clear and legible.
I suggest you to try Campfire Audio Andromeda. These earphones are perfect for genres like death metal, where the instruments are often layered and complex. They also have a great isolation.
When it comes to high-quality earphones for technical death metal, you must pay attention to some details. I can recommend you Shure SE846 and Klipsch X12i. I tried them both. These earphones are known for their clarity and precision. They're a great choice for technical death metal, where the fast and complex rhythms are often hard to hear. When I buy a new pair of earphones, I always test them.
Jesus, the state of this topic. A lad comes in asking for headphones recommendations and the condecending nerds decend on him. My advice - find a new, friendlier forum to ask this question.
The state of the topic is also that nothing happened for four years. But @RerryDan may have found it on top if some spambot had been here.
If now you argue that it isn't that important whether it happened four years ago if it would very well happen in four weeks again ... fair point. The tone of the forum can always be discussed, and it might be a bit overly aggro at times. (Says the arrogant swine.)
Truly good headphones are good for any genre.
Actually, there are many things that are hard to hear in technical death metal not because of technical death metal itself, but because the fact that most of modern metal recordings are mixed and/or mastered poorly.
Usually, I listen to https://www.youtube.com/watch?v=uSHYBhATo9c because the beats make me understand if the earphones' sound is good. But remember that personal preference plays a big role in what headphones you choose. Additionally, the fit is also important. So, make sure to try different types of ear tips to find the most comfortable and secure fit for you.
MOD Edit: move reply out of quoted text
A good site with testing results on buds and headphones.
https://crinacle.com/
"The lack of money is the root of all evil." - Mark Twain
https://www.heavys.com/ - but those are headphones, not earphones... I just thought of putting this link here, since the thread got resurrected. Maybe someone who stumbles on it will find this useful.
lame -V 0
I recomend Moondrop Lan.
Whatever headphones or speakers your stuck with , I think I know what
you mean by bass boosted.  What I do is make a mild V shaped dip in the bass freqs
using graphical EQ - this usually produces a clearer less muddy sound.  Good for most genres
, very good for metal and some electronic sounds. Maybe not great for heavy bass driven sound.
wavpack -b3.63hhcs.5
One with low distortion...
TheWellTemperedComputer.com
