Topic: cue sheet embedding bug (Read 859 times) previous topic - next topic
There appears to be a bug in foobar2000's embedding of cue sheets with large track lists.  If the cue sheet contains more than 100 tracks, the ARTIST field will be imported incorrectly into the FLAC file for all but the last 100.  For the rest, foobar2000 copies the ARTIST info from those last 100 tracks.
For example, if a FLAC file contains 140 tracks, #41 through #140 will be correct, but the ARTIST info in track #1-40 will be the ARTIST info from track #101-140.  And even when you try to edit track #1-40 manually using the "properties" feature, the ARTIST field still reverts to the ARTIST info from 100 tracks "later."
(Note:  I'm using version 1.4.)
Re: cue sheet embedding bug
Sorry, cannot reproduce.
Can you please share the affected FLAC file for me to look into?
