Topic: Opus gapless and glitchness encoding (Read 58740 times) previous topic - next topic
Re: Opus gapless and glitchness encoding
Reply #75
Oh that's cool. I'll simply use the source filename. Thanks.
Reply #76
I apologize to everyone who used the initial version of Gapless Opus Encoder, I was probably too excited to get it out and didn't spend time to verify that it worked correctly. I had simplified the logic too much when I patched in the RG scanner in last minute and had broken the encoding flow. Files encoded with it may not be 100% gapless and RG results are not right at all.
New version that I uploaded just now is actually verified to function as it should, I encoded my entire music library with it last night and verified the results this morning.
Other improvements are automatic handling of illegal filename characters. Character replacement follows the built-in Converter's modern character replacement setting from advanced preferences.
There's also an option to not overwrite files. Note that skipping some tracks within an album will break the gapless encoding flow as encoder will get reinitialized.
And I added ability to encode albums that have tracks with different specs. Encoder will just get reinitialized if format changes.
Reply #77
Hi Case. I've tried the updated version and converted 9 albums but none of the embedded album art has transferred to the converted OPUS files. All the other metadata has transferred across fine.
Reply #78
There is no functionality currently to do anything about album art. Metadata to me means text format tags.
