Topic: flac to aac help (Read 427 times) previous topic - next topic
flac to aac help
 An error occurred while writing to file (The encoder has terminated prematurely with code 2 (0x00000002); please re-check parameters)
I've been attempting to convert my flac file to AAC (Apple) using qaac on and the free encoder pack on foobar but it isn't working.
I'm almost certain it's me doing something incorrectly. I've tried downloaded itunes and as mentioned the encoder pack and qaac file but they don't register properly. It selects the folder instead of individual file idk if that's whats supposed to happen or not but well you know.
If anybody could send through exactly what I need to achieve the conversion that'd be lovely.
Any further advice would be greatly appreciated, a walk through would be savior !!
If it's easier I've heard fdk is good too, so if you know how to do either of the two don't hesitate in sharing info.
tyvm
Re: flac to aac help
Hi, let us know what guide you used and which foobar settings you are using.
I'm using these settings:
- At "Commandline Encoder Settings" i'm using these parameters: -s -V 63 -i --no-optimize -o %d -
- "Encoder file" should point to the qaac.exe file.
Hope this helps :).
Oh, if you don't want to install iTunes, but you do want to use the aac encoder. Then you should download iTunes here:
https://www.apple.com/lae/itunes/download/
Download from makeportable.zip from the qaac site:
https://sites.google.com/site/qaacpage/cabinet
Extract makeportable.zip to the same directory as "iTuned64Setup.exe", then start makeportable.cmd.
It should create 2 directories:
QTfiles
QTfiles64
Then copy the QTfiles directory where qaac.exe is located.
Your qaac directory should contain these files now:
libsoxconvolver.dll
libsoxr.dll
qaac.exe
refalac.exe
QTfiles\ASL.dll
QTfiles\CoreAudioToolbox.dll
QTfiles\CoreFoundation.dll
QTfiles\icudt55.dll
QTfiles\libdispatch.dll
QTfiles\libicuin.dll
QTfiles\libicuuc.dll
QTfiles\msvcp100.dll
QTfiles\msvcr100.dll
QTfiles\objc.dll
Same goes for the 64 bits version if you want to use that.
