Topic: ♦ CUERipper 2.1.7 ♦ MS Dot Net Framework Error Report (Read 15834 times) previous topic - next topic
Hello again, Everyone  :D
CUERipper flags a Microsoft Dot Net Framework error report at some rips. Please, help me by interpreting the attached reports of one such rip, and consequently advise me what I need to do to prevent a recurrence of it- if it is at all possible.
Thank you.
PS. Operating system Windows 7 x64, Terratec DMX 6 Fire soundcard, ASUS DRW-24B5ST CD/DVD-writer.
Re: ♦ CUERipper 2.1.7 ♦ MS Dot Net Framework Error Report
Seems to be the same as
https://hydrogenaud.io/index.php/topic,115962.0.html
Hello Korth
Yes, that's the one. Thank you for the pointer, which my own search did not turn up.
The OP reported his own fix for v2.1.6, preempting the author's investigation/fix. I am using v2.1.7, and it appears as if the solution is yet forthcoming for this version too? Could we, please, have an update?
For reference. I found another similar report on the old bug tracker.
Progress bar exception raised when ripping a CD with errors
While ripping a CD with 632 suspicious sectors, CUERipper 2.1.5 (May 2014 build) reached 100% on the progress bar before the end of the rip, and an exception was raised. See http://pastebin.com/PhwspDcH for the full exception message.
korth
