Topic: vgmstream plugin r1050-1468-gd1f16465 can't deocde xwav (Read 1253 times) previous topic - next topic
Hi, dear kode54. I want report a problem with vgmstream plugin.
Since which version, I don't remember. Currently I use  r1050-1468-gd1f16465 and it can't play xwav(rip from HALO 2 PC)
Unable to open item for playback (Unsupported format or corrupted file):
Re: vgmstream plugin r1050-1468-gd1f16465 can't deocde xwav
This file may be badly ripped? The RIFF length field specifies a size that is equal to the file size minus 4 bytes, which either means that 4 bytes were truncated off the file (it should be file size minus 8), or the size is wrong.
There are workarounds in the reader, but they don't appear to be employing properly for this file. There is a workaround for IMA ADPCM, like this file, but it only kicks in for riff_size == file_size, (and subtract 8) not riff_size == file_size - 4. (where it should subtract 4)
Thanks for reply, kode54.
I'm not very sure if these files were badly ripped, it was ripped using a tool called 'Gravemind' which is  for HALO 2 ripping only.
Maybe pc version difference...
Now I updated vgmstream plugin to r1050-1489-g03dd4383, and play xwav again. Thanks for your great work!
