Topic: FLAC in Ogg wrapper not a supported file format? (Read 1013 times) previous topic - next topic
With Foobar 1.4 (no 3rd party input plugins) I can stream this station that uses 24-bit FLAC in an Ogg wrapper with no problems:
http://secure.live-streams.nl/flac.flac
However, if I download the original stream using XMPlay (Streamripper cannot deal with FLAC or I would use that via foo_run) to a file, attempting to play it with Foobar results in "unsupported format", despite the fact it plays fine in FB as a live stream.  Same file will open and play in AIMP and XMPlay.  MediaInfo shows this for the downloaded file:
General
Complete name                            : C:\Streams\flac.flac
Format                                   : Ogg
Format/Info                              : Free Lossless Audio Codec
File size                                : 15.5 MiB
Duration                                 : 7 h 18 min
Overall bit rate mode                    : Variable
Overall bit rate                         : 4 957 b/s
FileExtension_Invalid                    : ogg ogm opus
Audio
Format                                   : FLAC
Bit rate mode                            : Variable
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 44.1 kHz
Bit depth                                : 24 bits
Writing library                          : libFLAC 1.2.1 (UTC 2007-09-17)
Any ideas as to why it won't play in FB?  Probably has something to do with the "FileExtension_Invalid" flag but then why would it play fine in the other two players?
Re: FLAC in Ogg wrapper not a supported file format?
Probably because foobar2000 does care about extension? Is it too difficult to rename it to .ogg (or .oga)?
Not too difficult at all, now that I know what the problem was, and THANK YOU Ivqcl for pointing out the solution  :) !  I should have figured that from the MediaInfo message, but I didn't key on the fact that it's actually suggesting the CORRECT extension to use, not invalid ones.
