Topic: MPC v0.90s says \'r\'? (Read 2852 times) previous topic - next topic
Can you locate that file on the page? I only see o & s.
When I encode using EAC (--xtreme %s %d), all goes well .. no errors, but when I try to play the file with Winamp (have latest plug-in), I get error:
Error:function play()
Superframe-size!=1 not supported any more. PLease decode withn command line tool.
When I encode with Speeks batch (same encoder), I don't get this error.
Winamp 2.78
Ideas?
disable adding of id3v2 tags in eac.
latest winamp plugin should ignore id3v2s. are you sure you have the latest one (0.90k)?
ps: try to download the files from musepack.org. they are up-to-date.
regards; ilikedirt
Thx for the reply.
Your sugestion worked like magic.
I *did* have k installed, but went and d/l'ed the .exe from
http://members.aol.com/pumpkinz99/
anyway. No diff. Same error. No problem.
'preciate the help.
Okay, downloaded version 'u' says 'u' (in the encoder).
Do you guys have any *decoding* suggestions? I see some switches available ...
