Topic: Converting stereo to binaural (Read 9460 times) previous topic - next topic
Anyone know of a way to convert a normal stereo recording to a quasi-binaural recording (for listening with headphones)?
I know there are some DSP plugins and such that will do something like that, and I'm wondering if there's something that really preserves accuracy and doesn't add an "artificial" quality to the soundstage -- something that sounds nearly like the original stereo had been recorded binaurally.  Any suggestions for specific programs or plugins (I use WinAMP)?
1. Use biophonic curve - sample eq file for foobar2k:
-3
-5
-6
-6
-6
-5
-5
-5
-4
-2
0
-3
-4
-5
-4
-2
0
2. Use crossfeed. (order isn't very important, but there is a difference)
ruxvilti'a
I have been using crossfeed, but not the eq settings. Thanks for cluing me in.
Could you tell me where the equalzer is in foobar? I've never had to use it and I can't find it anywhere. I'm using .667
I wonder the effect when this EQ setting is used with loudspeakers...
Binaural and regular stereo recording techniques are very different, so there is no way of converting a regular stereo recording into a true binaural equivalent, since the recording was not done binaural at all, and will lack tons of things you would have got at at a true binaural recording of the same source. With usual modern recordings, a binaural recording has not much sense. Only live events (concerts) are susceptible to be recorded binaurally.
Another thing is that you want that a regular stereo recording sounds the same using speakers or using headphones. This can be in theory be near perfectly achieved, but only for a particular room, listener location, speakers and headphones. And would require some acoustic measurements at that room, and some nice DSPing, mostly realtime convolution of responses.
A simpler and more generic approach is the use of a dsp crosfeed, that adds something similar in a gross manner to what the previous effect would add, and independently of the actual speakers/headphone/room used. However, some crossfeed parameters can be adjusted to try acomodate those in some gross way.
I think recording impuls responses with in-ear microphones (e.g. artificial head) one time from a pair of good speakers, one time with headphones and doing a "impulse response substraction" would work. Of course 4 channels would be needed because of crossfeed. Unfortunately I don't have the equipment, otherwise I'd already have tried.
Yes, that would be the way of doing it. I believe it all can be done using Aurora set of plugins for CEP, but you need also a in-ear microphone to perform the measurements. But I think you could use your own head.
<snip>
Is this really correct?
"Ear canal resonance" should be the same no matter if you use headpones or speakers (besides the headphones are located in the "ear canal" - So at least at this position the curve could be improved, I guess.
And isn't there already some built-in equalization in crossfeed that takes that biphonic courve into account?
No, crossfeed is just that, crossfeed.
Copying HF (don't know how high) parts of one channel to second minus 15dB AFAIK.
Ask Trelane for details.
Ear canal resonance is more pronounced using heaphones, I think.
I don't know exactly, I didn't create this curve.
ruxvilti'a
The equaliser is part of the 'standard' dsp plugin. You can download this plugin from the front download page of Foobar2k.
