Topic: USAC (xHE-AAC) sample rate and bit rate (Read 4412 times) previous topic - next topic
I'd like to know Sample rate and bit rate range supported by USAC.
Re: USAC (xHE-AAC) sample rate and bit rate
Lossy formats don't support a specific range of sample bits. Individual encoders might only accept certain sample sizes, but the format has no limit.
Sample rates should be the same as AAC as far as I know. It's backwards compatible.
No, it's not. The bitstream format ist different from previous versions of AAC. xHE-AAC use a more efficient type of entropy coding.
Well, yes and no.
The answer is: There are two different profiles of xHE-ACC
One that uses the old bitstream format (Huffman-coding)
and the other one that uses the new, non-backwarts compatible bitstream coding (CBAC).
