Topic: foo_enhanced_spectrum_analyzer (Read 61450 times) previous topic - next topic
Re: foo_enhanced_spectrum_analyzer
Reply #175
Love this component, but just a couple of anomalies:
Even though I have tooltips turned on, I don't get a readout of the note frequency when I hover over a frequency bar, like I did with the old Musical Spectrum. Any way to do this?
Also, the vertical Octave divider lines don't coincide exactly with the actual frequency bars, which look kinda messy. If there's a setting I'm missing, please let me know. I'm trying to get as close to the old Musical Spectrum settings I had, as possible.
Reply #176
Another weird one, it seems to lag significantly behind the audio, what's the setting I need to adjust to get it in sync with the music?
Reply #177
While there is no such thing as "Reaction alignment" parameter as in foo_vis_spectrum_analyzer, you can lower the FFT size to 4096 or lower to get better sync through it loses the frequency resolution and also, the amount of delay ahead actual playback in proportion of FFT size parameter is exactly the same as this relevant CodePen project with something like "delay compensation" enabled
BTW, I would assume that if IIR filter bank mode is added, the filter bank-based musical spectrum doesn't have this problem of lagging behind the audio and have equal resolution for all frequencies in logarithmic frequency scale
Reply #178
Feature request (for another FR to display multiple channels at once): Treat stereo pairs or Mid/Side representations as complex numbers for FFT input data
As in the Codepen project " Spectrum analyzer and spectrogram using custom FFT ", the first graph is as it is but the second one is exactly the same as one but flipped (looking at "negative" frequencies) in FFT bin index ordering
Reply #180
There is no such thing as tooltips for foo_enhanced_spectrum_analyzer currently, though sneak peeks posted by @Crossover suggests that upcoming version 2.0.0.0 for Enhanced Spectrum analyzer component could have tooltips added
BTW, do you mean foo_vis_spectrum_analyzer instead of foo_enhanced_spectrum_analyzer?
Because again, frequency bands mode is currently not available for Enhanced Spectrum analyzer component, though upcoming Enhanced Spectrum analyzer 2.0.0.0 could have one, like my dream I've experienced last time where this component got an update that not only added Musical Spectrum-esque bars but also an option to use IIR filter bank instead of FFT
Reply #181
Thanks, ah yes, think I posted in the wrong thread! Very confusing having two components with very similar functions and names!
Reply #182
Yep, your posts (that is actually about foo_vis_spectrum_analyzer) almost made me think that version 2 of this component was released when really is not yet
Reply #184
Couple of (seemingly-endless) feature requests for this component: Infinite decay rate mode, fading peaks, and difference coloring for labels and grids
As for the first, it works best if enabled by default for "Average" spectrum (alongside 0ms hold for Average spectrum by default), but it can be anything including "Peak" spectrum because foobar2000's built-in Spectrum and old foo_musical_spectrum by @fismineur doesn't have slow falloff for main bar unlike in Spectralissime and this component, and what this setting does is completely remove the gradual falloff (and the make this visualizer react the fastest as possible) and to avoid flickering look, it cumulates peaks since previous frame, up to 576 samples (only on "Peak" spectrum and IIR filter bank is used instead of FFT)
As for the second, it is an aesthetic look for peaks, very similar to audio visualizer from Geometry Dash 2.2 (in terms of fading peaks) and it is for "Peak Max" spectrum, works best when "infinite falloff" is turned on as in the first FR on this post
As for the third, it helps (to see the labels or grid more clearly) when the spectrum and label/grid shares its colors by using the blending operation similar to CanvasRenderingContext2D.globalCompositeOperation = 'difference' for the grid and labels, something like this:
X
X
Reply #185
I have several questions about this component that I originally posted over PMs to @Crossover that haven't responded to me and I feel like some of my questions originally directed towards the dev can be answered by anyone else:
  • Are sinc/Lanczos interpolation used on frequency bands mode when not using IIR filter bank mode? If not, what other FFT bin interpolation is used?
  • Was setting window function does actually nothing, a regression introduced in version 1.9.2.0?
  • Speaking of IIR filter bank analyzer, have @Crossover saw these filter bank-based octave band analyzers besides my own CodePen project about the filter bank spectrum analyzer?
  • Do you think that use of AVX2 and/or even AVX512 instructions is necessary for foo_enhanced_spectrum_analyzer especially with IIR filter bank mode (especially with steep 192dB per octave rolloff and 1/48th octave bands)?
  • BTW, are @Crossover busy with other stuff? Since I haven't seen you replying to my PMs nor seen you posting something new on this thread nor anywhere else yet
  • Should this component (including Loudness Peakmeter) be listed in official foobar2000 Components Repository site?
  • What you're actually doing stuffs if you're not active on HydrogenAudio forums?
  • When will be the beta version of Enhanced Spectrum analyzer 2.0.0.0 that we can check them out?
  • For sanity check, is it realistic for upcoming version of Enhanced Spectrum analyzer 2.x.x.x to meet up my expectations and/or look similarly to these mockups I've made?
BTW, an adjustable number of bands-per-octave is needed for 1/3rd and full-octave bands analyzer (even 1/24th, 1/48th, 1/96th, and even 1/192th octave bands) in this component
Reply #186
Maybe watching TV or visiting friends or.. ;)
I don't think crossover is working for/towards anyone's personal design expectations besides his own.
TF3RDL, your theoretical and conceptual knowledge of spectrum implementation is impressive.  What I don't understand is why you don't make the jump from CodePen to plugin development yourself?  You're bursting with good ideas, make them happen, instead of just cajoling others here to do so.
Reply #187
Agreed with the first sentence, while I made these CodePen projects (because I started programming in JavaScript to make interactive stuffs that any DSP nerds might get interested) that have some good ideas, I don't have necessary programming skills to make actually a foobar2000 component (which in turns requires learning C++ and setting up Visual Studio/VS correctly for fb2k component development I guess) myself
BTW, "cajoling" means persistently begging others (in this case, @Crossover) to make something that I don't have necessary skills (in this case, my ability or lack thereof to program a fb2k component on C++) to make it happen, which could be a bad idea right? Considering letting @Crossover cook this new update would be a good idea
Reply #188
BTW, another feature request for this component that is for nerds: Monitoring fields (from Loudness Peakmeter component)
Displays single-valued spectral features like spectral centroid, flatness, slope, rolloff, spread, skewness, kurtosis, and crest (not to be confused with Crest spectrum that I'd like to be brought back from the old version of this component as spectral crest feature is single-valued; it visualizes the difference between max of and RMS of the entire FFT spectrum), and each spectral features on monitoring fields area has a bar that display the current value in-addition to the value in text unlike the Loudness Peakmeter, which only display the current value in a text form
Also, I love to see displaying lines showing current spectral centroid/rolloff/spread values in Hz and scaled accordingly to the graph's X-axis scale and frequency range
