Topic: CD ripped CUE FLAC dither? (Read 1770 times) previous topic - next topic
Using foobar to split CUE files into individual tracks (because I have read the Medieval CUE splitter is BAD).
When converting in foobar, (if set to ALWAYS) the output WILL HAVE DITHER only when a bit change has occured, correct?
Currently, I'm converting EAC ripped CDs to FLAC with a cue file I made like a decade or more ago. I know this is a stupid question but I just want to verify before I proceed with my probably hundreds hours of work. But my question applies to any bit depth/audio file type really.
So in my above scenario with CD rips, even though dither is set to ALWAYS, the output file in fact won't be dithered because I have my output set to 16bit, correct?
Thanks for the (hopefully very quick) answer and help!
Ben
Re: CD ripped CUE FLAC dither?
The "always" option indeed means always. It will dither even when bitdepth doesn't change.
Okay, I'm very glad I asked then. I wish there was an "only on bit change" option then.
Thanks for the response.
Ben
