Topic: Newbie question (Read 2772 times) previous topic - next topic
Newbie question
Can someone explain in layman’s terms what a Cue Sheet is? I’m trying to have a better understanding of the process before I start ripping CDs.
Re: Newbie question
http://wiki.hydrogenaud.io/index.php?title=Cue_sheet
Personally I don't bother with the cue sheet stuff as it seems like overkill.
since this is in the FLAC part of the forums... just make your FLAC files (with Exact Audio Copy etc) and then you can keep those for archiving and then if you need to re-rip to a lossy audio format (MP3/AAC etc) it's pretty easy with the FLAC files using Foobar2000. basically one i got the FLAC files i pretty much do all my audio conversion using Foobar2000. like to rip a full audio CD using Foobar2000 from FLAC to say MP3 or AAC takes roughly 1min tops (this varies based on CPU power, but that's should be a ball park figure).
on a side note... Foobar2000 works with cue sheets.
For music I suggest (using Foobar2000)... MP3 (LAME) @ V5 (130kbps). NOTE: using on AGPTEK-U3 as of Mar 18th 2021. I use 'fatsort' (on Linux) so MP3's are listed in proper order on AGPTEK-U3.
Re: Newbie question
If you tried, say, the transition between tracks 1 and 2 on the Aerosmith  album 'Get a Grip', I doubt you'd still seriously consider it overkill - at least for such cases.
União e reconstrução
Re: Newbie question
I've only used cue sheets for making CDs.    It's particularly useful for placing the track markers when you've got a single WAV file.     i.e. It's a great way of making a "live" CD with no gaps between songs.
