Topic: Preserving directory and sub-directory structures when converting (Read 615 times) previous topic - next topic
Hi. Sorry if this is addressed elsewhere, but I've looked and can't find the answer.
I have a directory that reads as follows:
c:/Input
Input/subdir-1/files*.*
Input/subdir-2/files*.*
Input/subdir-3/files*.*
etc.
I am converting, and I have an /Output folder, and the default is taking all of the files in the subdirectories and putting them all into the /Output folder, all of them. This is not what I want.
What I want is the converted files to go into a directory structure just like existed before. So that I have:
c:/Output
c:/Output/subdir-1/converted-files*.*
c:/Output/subdir-2/converted-files*.*
and so on.
What settings do I do for that?
Re: Preserving directory and sub-directory structures when converting
You'll need to put C:\Output in the Output path>Specify folder.
For the name format, you can use...
$replace($directory_path(%path%)\%filename%,C:\Input,)
If it was just one folder deep for all files, you could use
%directory%\%filename%
but I thought that was probably unlikely??
Thank you!
