Topic: foo_upnp The UPnP Media Server could not be started (Read 214 times) previous topic - next topic
Can somebody help me what do to if:
The UPnP Media Server could not be started. Port 56923 *might* be in use by another application or foo_upnp instance.
I deinstalled foo_upnp.fb2k-component and installed new.
The same Popup
Re: foo_upnp The UPnP Media Server could not be started
Do you use torrent? Or other download clients/protocols? Do you host or connect to any specific services (game servers, home media server, home confort control systems, IP intercoms, SIP services, whatever else)? I suppose you get this error because something like this occurs on your OS. Does the same error occurs after PC is restarted? If not I suppose it is something like torrent (randomly choosing port at each stary). If yes, then try netstat command from Command Prompt (look for switches list to see enough details) or Wireshark for more advanced network traffic analysis.
SimplePortal 1.0.0 RC1 © 2008-2018
