Topic: foo_scrobble (Read 51624 times) previous topic - next topic
Re: foo_scrobble
Reply #125
A quick update:
I gave it another try today and noticed that while some tracks scrobbled, some did not.
After analysing my tracks with foo_texttools and comparing with what's submitted to foo_scrobble, it turned out to be a %musicbrainz_trackid% issue.
I use beets for library organization and I fetch all my tags from Deezer, By doing so, the %musicbrainz_trackid% is overwritten by the Deezer track/album ID, which obviously isn't compatible with Last.fm. Clearing the field solved my problems and all is good.
tl;dr - Check if your tag for %musicbrainz_trackid% is a valid musicbrainz ID. If not, clear the field for it on the foo_scrobble options.
Re: foo_scrobble
Reply #126
Hi!
Is there any possibility of getting a port of this to mac?
Re: foo_scrobble
Reply #127
For standalone recordings that don't have a track_id (and instead have a recording_id), does Last.fm accept the recording_id? Or is track_id the only valid field it accepts? Would this $if work if it does?
$if(%MUSICBRAINZ_TRACKID%,%MUSICBRAINZ_TRACKID%,%MUSICBRAINZ RECORDING ID%)
