Topic: Biography Text, Album Info, Picture. www.last.fm (Read 76405 times) previous topic - next topic - Topic derived from Re: WSH Panel Mod scr...
WSH Biography Text, Album Info, Picture. www.last.fm
language - left mouse double click on the text (or main menu or menu properties to set);
font size - shif + mouse wheel on the text;
move text - press left mouse button on the text and move;
previous, next img. - mouse wheel on the img;
selsect artist or album img. - left mouse double click on the img  (order by most popular or release date - menu);
img. interval setting - shift + mouse wheel on the img;
UR5EQF. Ukraine
Re: Biography Text, Album Info, Picture. www.last.fm
Thank you @kgena_ua  :)
Thank you , always use your script!
glad to be useful
UR5EQF. Ukraine
а можно скрипт паправит так, штоб с начала брал инфо с поля REMIXED BY, а потом (если инфо нет) уже с ALBUM ARTIST ?
мне как то правилнее если у песни дапустим ABBA (remix от TIESTO) паказывал дискографию TIESTO
Violation TOS  #10. You must post in English.
sorry, can you delete my message (i translate with google) ?
Is it possible to adjust the script so that at the beginning it will be taken info from the REMIXED field, then (if there is no information) from the ALBUM ARTIST field?
It seems to me more logical, for example: the song ABBA remixed TIESTO, so better that the TIESTO discography is displayed.
THANK YOU for answer.
Biography, Albums, Similar artist info. www.last.fm
version 06102017
language - left mouse (or left mouse + Shift)  double click on the text  (main menu or menu properties to set);
font size - Shif + mouse wheel on the text or text header (menu properties to set);
hide text - mouse mbtn dblclk on the text header;
select artist, albums or similar artisr info - left mouse double click on the img  (main menu);
img. interval setting - Shift + mouse wheel on the img;
for advanced settings see menu properties.
The script is not compatible with the previous version, saved data must be deleted/
UR5EQF. Ukraine
thanks, super :)
Thank you. Works perfect.
@kgena_ua
can't get album-review
(old bio-tool gets album-review)
language: english
changed to album: most popular or release date - nothing found
i'm using foo_jscript-panel 1.3.0 and
your tool 06102917
please have a look at it,
thx
@lender1257,
I think you have not deleted the old data from the folder " ...\tmp_Biography".
(do not delete folder "_download")
UR5EQF. Ukraine
I'll check it at home
UR5EQF. Ukraine
hi
can you please also implement a remap-field for %artist%?
owing to different spellings
thx
@lender1257
I do not even know. I checked it with foo_jscript_panel-v1.3.0.
Works good
Spoiler (click to show/hide)
UR5EQF. Ukraine
hi
thanks for checking.
in the video your script shows in line 1811 "var btn=WshShell ... Foobar 2000 ..."
in my downloaded script (version: 06102017 feature: v1.4) there isn't such a line
my script ends with line 1786
if i change to "similar artists" always "text not found"
any idea what i have done wrong or did i grab the wrong sript ?
@kgena_ua
error found; it was my mistake, changed parameter "download limit" to zero
                   i thought concerned pics only
script works
feature request: album-review of playing %album%
                         remap-field %artist%
thx
All right, the script ends on line 1786.
I additionally wrote a function for deleting empty folders and testing it now.
UR5EQF. Ukraine
hi
are you planning to expand your script like wrote in post #18 ?
@lender1257,
You mean to add a search for an %artist% - %album%  that is playing or currently selected
UR5EQF. Ukraine
hi
kgena_ua
yeah, double-click on panel changes from "bio %artist%" to "album-review %artist% + %album%" and reverse.
if not possible, then an extra script
first, a way to overwrite %artist% (remap %artist%) would be very good. with this you could correct different spellings.
thx
Hi
kgena_ua,
Thank you very much. I have used this script,It is very helpful to get the music's information.
But it has some little problems:
1)It omit some special charactors,like as "*,/,.". It will be much better to change these charactors to '_'.
2) It cann't fetch the playing music's album cover.(Not the artist's pop album)
3) When you change the music quckily,it will get wrong images.(settings:prefer now plaing)
4)  It will be much better if it can set these parameters: the dowloaded image path(default: tmp_Biography) ; the artist's images's suffix(_?_images);the  album's images(eg.: $if(%album artist%,%album artist% - %album%,%filename_ext%)
Could you please fix these problems? I find this script is the best than others so far.
Have a good day!
@kgena_ua
really great script !!!
if you include "album review" in the context menu, please change in properties,"default img path" to "default img path bio" and allow a new path for "album review" (default img path album review).
so that 2 different images can be displayed if nothing is found.
thx
