Topic: Is there any way to change toolbar color? (Read 3870 times) previous topic - next topic
I've themed my foobar based on black and green colors and the toolbar is the only thing left that's not colored. I'm wondering is there a way to change the color of the toolbar without 3rd party components. If there is no way, what's the best way to do it and what components to use?
I'm using Column UI btw.
This is how it looks with the gray toolbar:
Thanks in advance, any tips will help.
Re: Is there any way to change toolbar color?
AFAIK not from withing foobar2000, you'd need to change your windows theme assuming you're using windows.
There are plenty of Columns UI skins that hide the main menu (typically replacing its functionality with other elements), but as jazz said I don't believe fb2k itself provides a way to change the window chrome colors. Here's one such CUI skin that appears to have the menu as an icon instead (been a while since I tested that skin though so could be incorrect).
I use the Default UI for my setup so unfortunately can't point you to a simple main menu alternative. I know Jscript Panel has a themeable seekbar replacement though.
