Topic: Biography Discussion (Read 174222 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Re: Biography Discussion
Reply #825
^ You could try enable "Album name auto-clean" setting (in Options > Server Settings tab (blue) > Miscellaneous tab) - description of it is written at the bottom.
Reply #827
this definitely seemed like it would be the answer based on its description, thank you! unfortunately i couldn't get it to work even after resetting the cache and forcing updates.
as an experiment i made a new tag field called "album_clean" and manually created a tag for "Meddle" vs "Meddle (German)", went to server settings>title format and changed %BIO_ALBUM% to "$if2(%album_clean%, %album%)" which works as expected (but still doesn't clean the tag if it falls back to %album%). i'm wondering if perhaps the "utils.ReplaceIllegalChars" function is broken in v2 (32 bit)?
Reply #828
No such thing exists in Spider Monkey Panel. That's in JScript Panel only (v2.5 and above). And it's for replacing illegal characters in windows file/folder names - nothing to do with the subject at hand.
Reply #829
oh gosh thank you, somehow i hadn't noticed i was exploring around the jscript folder not the SMP folder, oops!  :-[
in any case though, given my limited (to say the least) understanding of javascript the SMP js files are even more cryptic to me. i am guessing that it must be something i'm doing wrong but i'm not sure what else to do besides manually creating a separate clean album title tag. the "clean album title" checkbox doesn't seem to have any effect even if the match % numbers are turned way down.
thanks again for the clarification Marc (and for all of your other work), if anyone has any suggestions i'm open to them! :)
edit: I managed to get it working by adding "replace(/\([^)]*\)/g, ' ')" to the albumClean function in names.js!
Reply #830
Could you make a x64 Jscript 3 version? I miss this beautiful biography on foobar2000 x64.
Reply #831
I get the following error:
ActiveX_Run failed:
ActiveXObject:
  code: 0x80070005
  description: Access is denied.
  source: msxml3.dll
File: lastfm.js
Line: 638, Column: 16
Stack trace:
  search@lastfm.js:638:16
  analyse@lastfm.js:662:19
  onStateChange@lastfm.js:580:42
  getTrack/dl_lfm_track<@server.js:579:58
Reply #833
how can I install this on jscript-panel 3.1.18???
Reply #834
Does the biography panel have an option to manually add a search? I have a lot of radio stations that don't add metadata of a track properly and are not properly parsed into %title%, %artist%, and then the panel finds nothing. I'd like to see the background info in the panel by just typing in the search.
Reply #835
@marc2k3
@WilB
guys, help - the monkey panel doesn't work on version 2.0, I can't live without a biography!!! How to install???
Reply #836
SMP and WilB's script should work fine on 32bit fb2k v2.
Since 64bit is brand new, no one can claim to need it. It's nice but not essential. If you have one more components that aren't available, it makes the choice so much easier. You'd be mad to give up things you find useful just to use it,
64bit JScript Panel 3 does include last.fm bio and image downloading scripts (thumbs) but of course they're rather basic compared to WilB's work. I'm useless at making things look pretty.
https://jscript-panel.github.io/gallery/lastfm-bio/
https://jscript-panel.github.io/gallery/thumbs/
Reply #837
just reporting - randomly occurs:
Error: Spider Monkey Panel v1.6.1 ({E8C329D3-03E9-4ABF-A58B-871009A023E5}: Biography v1.3.5 by WilB)
File: server.js
Line: 186, Column: 10
Stack trace:
  expired@server.js:186:10
  getRev@server.js:426:51
  download@server.js:193:8
  Server/this.on_playback_new_track<@server.js:47:9
  T@helpers.js:97:164
  t@helpers.js:97:519
  on_playback_new_track@callbacks.js:434:23
Reply #838
Seems to be pointing at a helper function inside scripts\helpers.js
At line 116, replace this...
	file(f) {
return fso.FileExists(f);
folder(fo) {
return fso.FolderExists(fo);
with
	file(f) {
return typeof f === 'string' && fso.FileExists(f);
folder(fo) {
return typeof fo === 'string' && fso.FolderExists(fo);
Reply #839
Just noticed sometimes Last.fm is missing the locale tag, but it's present on the wiki data.
According to tagger.js file, locale tag is only filled with the last.fm value, so in some cases the panel does not notify the country even if it's shown on the bio panel (the flag).
X
X
Wiki/allmusic values should be used as fallback in case last.fm value is missing on window.NotifyOthers('biographyTags', ...)
Reply #840
I've added the fall-back for the next version.
Thanks for the feedback.
Reply #841
how to install it ? I tried two jscrpit panels select Import choose Biography-v1.3.5.zip and everytime javascript error ?
Reply #842
In the summary, not all items adjust with the panel width. I noticed that in genres, moods and members
Reply #843
I find many .txt files in the main folder of foobar2000
These files refer to the artist's biography.
It often happens when I add music files into the playlist.
I didn't understand if I have to set something in the tool to avoid this.
Reply #844
In foobar->Menu->Preferences->Columns UI->Spider Monkey Panel->Configure panel->Spider Monkey Panel Configuration->Package->Package manager->Import->Biography (by WilB->Biography-v1.3.5.zip
What is the opposite of music?
Reply #845
In foobar->right click in Biography field>Options->Biography Options->Server Settings (All Panels)->Download->Auto-download->Untick...
Reply #846
@aboabo  The issue of handling radio streams that contain the artist name and song title in a non-standard format has a arisen a few times. Rather than putting in a manual search, the next version should have an advanced radio stream parser so it works automatically. It has to be configured for each problematical stream which the user can do. It uses JavaScript. So far it has two cases present, as provided by @Sergey77  in a pm a while ago. I'm happy to add a few more, really as examples, and so if any one wants to post some radio stream links that are not properly parsed into %title% %artist% I'll look into adding them.
@paregistrase  To have a neat and compact summary, certain items are limited to one line by design. That particularly applies to items where there might be long lists, e.g. sometimes there can be 25+ members or moods etc, which would require several lines to accommodate.
@ApacheReal  That issue should be fixed in the next version.
Reply #847
So no bug, a feature :-P
And any easy way to do it for people without concerns for vertical space (or aesthetic taste)?
One can scroll down easily, but the horizontal space is limited .
Reply #848
hey there, i was just wondering if there's a way to disable filmstrip. i can't figure out how to disable it in the options window and i'm kind of at a loss.
if it can't be disabled, what's the latest version that didn't have it?
edit: jesus christ i'm blind lol it's in the context menu. never mind  :o
Reply #849
sorry to double post. i want to continue using only last.fm photos, but this one artist's last.fm page is taken by another artist, and his own page isn't under his name -- so the photos that show are of some random pop group
is there any way around this? maybe disable last.fm photos for this one specific artist, or somehow make the plugin pull info from his actual page as opposed to the one his name's actually under? if not, is there a way to just upload custom photos?
allmusic has a bio for him so no issue there
