Topic: Biography Discussion (Read 245075 times) previous topic - next topic
Re: Biography Discussion
Reply #825
So are you saying it all works now? Either way I just tested on fresh fb2k 1.6.11 install with bio at all default settings. It all works fine for me even with those albums. See pics:
No. It still happens.
I close foobar. Delete all files related to KMDM and LA Vampires Meets Zola Jesus in the yttm folder.
I run foobar, select one KMDM release (with wiki info) and before LA Vampires Meets Zola Jesus (no wiki info)
and again
Only with the wki source.
Deleting the wrong files and force update seems to get the right results for this release (no new wiki files display or saved), but changing to another one with wiki and returning bring back again mixed results
Reply #826
@WilB
I deleted the script, close foobar, deleted all the config files and start fresh.
I found a difference between my .cfg and the new default.
   "autoCache": 1,
In the old one was 0
With the 1 value the wiki source didn't get stuck
Then I changed the paths to my yttm custom folder in 'Musica'.
But now it didn't save the images and txt files in 'Musica/yttm' anymore. They are saved inside 'biography_cache' inside foobar profile
Reply #827
It really shouldn't matter whether custom or default cache is used. I tried with both with your test albums.
As nobody else seems to have seen the issue, it's best to do further debug via pm. I'll send something shortly.
Reply #828
So autocache 0 or 1 is to change between default and custom.
Well, now with autocahe 0 it works well.  :-\  . I tried with all the albums that gives me problems and all of them works now
could be some mess up in the update process to the new version?
I'll tell you if I see something similar again but for now seems to go fine.
Sorry for making you waste time, I should have tried to do a clean start before report it.
Reply #830
New Version: Biography v1.3.1
Enhancement and optimization of new features.
Thanks for the new features and bug fixes (that Wikipedia bug was an elusive m*f*  ;) )
Said that, I think I need a little help configuring the image sources the way I like.
I have two sources for cover and artists photo, discogs_tagger and biography panel.
discogs_tagger download cover images to $directory_path(%path%) as album art_[number] and artist photo to Musica\Data\artist_art\%DISCOGS_ARTIST_ID%\%DISCOGS_ARTIST_ID%_[number]
I would like to download all the possible images that biography can download to Musica\Data\art_img and  Musica\Data\rev_img even if there is already a valid cover in $directory_path(%path%)
And display
In cycle bio artist the images of Musica\Data\artist_art\%DISCOGS_ARTIST_ID% + Musica\Data\art_img
In cycle bio review the images of Musica\Data\rev_img + $directory_path(%path%)
But I'm not able to achieve it.
what would be the correct combination of folders and custom folders for that?
Reply #831
If I understand you correctly you can try the following:
Photos
You should be able to set Musica\Data\artist_art\%DISCOGS_ARTIST_ID% as the photo > custom folder, which is checked first. If no images are found it will fallback to the download folder (Musica\Data\art_img).
So if you want the discogs photos, when images are available, enable menu> sources > photo > ...custom. If you want the art_img enable the menu> sources > photo > ...download folder.
If, as I believe you're on Wine and biography.cfg is being directly edited use, \\ not \ e.g. Z:\\Musica\\Data\\artist_art\\%DISCOGS_ARTIST_ID%
Review images
I'm not really sure why the rev_img is required if the album art cover is present. Consequently, the behavior is to only download rev_img if the cover is missing. To force it to get rev_img you could block loading of the album art cover until you have them. It's also possible to remove the check with a small edit:
Comment out lines 336 & 337 in server.js:
//const g_img = utils.GetAlbumArtV2(handle, 0, false);
//if (g_img) return;
I think that would be all that's needed in your case, but there are some tricky scenarios and so its not present as an option.
That should then save the rev_img.
Load:
1) $directory_path(%path%): e.g. use fb2k display > front. You can also use back cover etc if you have them.
2) rev_img: in covers: cycle folder (foCycCov) enter, e.g.  Z:\Musica\Data\rev_img (use \\ not \ if directly editing biography cfg)
    - note that your folder puts the review cover images by all artists in the same place
    - so adjust if you didn't mean that or include %BIO_ALBUMARTIST% & %BIO_ALBUM% in the path if you want one image per folder
    - either way the covers: cycle folder & review albumart save folder should be the same
3) On menu sources > cover enable: cycle above [set to front etc]  & cycle from folder
Reply #832
Photos
That's what I manged to do, 2 directories and change the display in the menu.
I wonder if there is a way to display the 2 directories at once. A menu entry like the one for cover folder and foobar default photos where you can select more than one source and all are displayed and cycled at the same time.
Review images
Load:
I understand the logic. In a normal case there is no need to download a new cover if there is already one, but with the cover downloaded from discogs there's a potencial use.
Sometimes these images are literal photos of the album over a table, have the stickers, prices, etc. or there are specific to the album release (Japan version for example).
Instead the last.fm, allmusic are usually a standard image of the cover.
With that edit, I can download the rev_img without checking if it is already present and use the default fb2k to have two folder. Clever
But i need to do it inversely.
Using the rev_img to the fb2k display because there is only one and point the cycle folder to the $directory_path(%path%) that contains more than one.
So I need to recreate "Z:\\mnt\\wd\\Musica\\Data\\rev_img\\$lower($cut(%BIO_ALBUMARTIST%,1))\\%BIO_ALBUMARTIST%", with %album artist% because %bio_albumartist% is not accessible outside the component right?.
In the default artist image I use this replaces to show one image from the script folder
['Z:\mnt\wd\Musica\Data\art_img\'$lower($replace($cut($meta(ARTIST,0),1),.,_))'\'$replace($if($stricmp($cut($meta(ARTIST,0),1),.),_$substr($meta(ARTIST,0),2,$len($meta(ARTIST,0))),$meta(ARTIST,0)),'/','-',':','-','?',)'\'*]
Will the same replaces work with bio_album, or I need something more?
And out of curiosity...what are the possible problems?
Reply #833
Well, at least for the cover, I think I do it.
I edit the server.js.
In biography.cfg
   "foCycCov": "$directory_path(%path%)",
   "foImgCov": "Z:\\mnt\\wd\\Musica\\Data\\rev_img\\$lower($cut(%BIO_ALBUMARTIST%,1))\\%BIO_ALBUMARTIST%\\%BIO_ALBUM%",
   "foImgRev": "Z:\\mnt\\wd\\Musica\\Data\\rev_img\\$lower($cut(%BIO_ALBUMARTIST%,1))\\%BIO_ALBUMARTIST%\\%BIO_ALBUM%",
In fb2k cover display
['z:\mnt\wd\musica\data\rev_img\'$lower($replace($cut($meta(ALBUM ARTIST,0),1),.,_))'\'$replace($if($stricmp($cut($meta(ALBUM ARTIST,0),1),.),_$substr($meta(ALBUM ARTIST,0),2,$len($meta(ALBUM ARTIST,0))),$meta(ALBUM ARTIST,0)),'/','-',':','-','?',)'\'$replace($if($stricmp($cut($meta(ALBUM,0),1),.),_$substr($meta(ALBUM,0),2,$len($meta(ALBUM,0))),$meta(ALBUM,0)),'/','-',':','-','?',)'\'*]
In bio sources-cycle  from folder and front
I tried some albums and seems to work. Even display the cover from rev_img first  8)
With the folder you said, it didn't download the cover to rev_image\first letter\album artist\album artist - album.jpg,
Good enough.
If it is possible to merge the artist photos, will be great, but if not I can live with 2 directories and changes between them.
Thanks a lot
Edit:
Even easier. foCycCov, foImgCov, foImgRev point to $directory_path(%path%). As the file downloaded is named cover didn't interference with the one downloaded with discogs tagger. Renaming the album art_ to scan_ to make them display after cover and voilä.
Fewer directories to managed, simpler scripts and more compatible with other softwares.
Reply #834
Wilb
When I click the left mouse button on the image, I get the following error:
Error: Spider Monkey Panel v1.6.2-dev+fddbb743 ({DE304636-11CC-4453-A396-69E39A6D7564}: Biography v1.3.1 by WilB)
o.composer is undefined
File: text.js
Line: 1463, Column: 17
Stack trace:
  isTrackRevAvail@text.js:1463:17
  wikiRev@text.js:2099:29
  getText@text.js:1276:11
  getItem@text.js:1048:10
  click@panel.js:401:84
  on_mouse_lbtn_up@callbacks.js:181:79
I comment line 1460-1464 in text.js, and the error has disappeared.
My question is - what is the "isTrackRevAvail" function for?
Reply #835
@paregistrase
I'm glad you now have it sorted.
...possible to merge the artist photos
I use the feature & in my case there are duplicates between the folders & I didn't want them merged. I checked a few discogs vs lfm ones and there seemed to be some duplication of images in those two sources as well. You can always merge them yourself into the lastfm download folder. I can understand you might not want to do that, but at least there is a solution. If you decide to try, I suggest using a back-up copy in case it doesn't work out. Make sure 'Image Filter Lastfm' in panel properties is off else the discogs images won't display.
@pIv
isTrackRevAvail should be fixed in the next version
It's used to set the grayed status of "Track review" on the load menu.
Also fixed for the next version is a regression in set language.
Reply #836
The duplicates were one of the reason I want to merge them in the display, to be able to spot them and delete them.
I understand that it is not good to display duplicates to the general public.
Seems that I need to rethink my folder structure to artist pictures.
Reply #837
Withdrawn
Reply #839
New Version: Biography v1.3.2
- Improved load sub-menu
- Fixed v1.3.1 regressions
Pop up prompt:
this.topAlbums.push is not a function
File: lastfm.js
Line: 153, Column: 80
Stack trace:
analyse/<@lastfm.js:153:80
htmlParse@helpers.js:176:11
analyse@lastfm.js:152:8
onStateChange@lastfm.js:31:42
getBio/dl_lfm_bio<@server.js:235:60
config@popupbox.js:46:9
open@settings.js:378:58
func@menu.js:725:25
run@menu.js:107:3
load@menu.js:70:8
rbtn_up@menu.js:1157:8
on_mouse_rbtn_up@callbacks.js:239:6
Reply #840
Great version @WilB.
I must say that I'm a great fan of the new system of filtering last.fm tags, some of them are just insane.
And I was wondering....why not expand that to all genre tags?
I was thinking in a text file with allowed last.fm tags (allmusic and wikipedia doesn't have garbage tags) for easy display and editing, eliminating the need of open the cfg or js files.
And centralized replaces file that will apply to all genre tags written to files.
This text files would be accessible from right click menu tagger section.
This will bring an easy to read and edit view of the tags that would be written to files and bring homogeneity to all the sources and avoid things like that
what do you think about it?
Reply #841
Small issue with v1.3.2. In Options >Display tab I have Album Ratings switched off, but Allmusic reviews are now showing the rating in the text (it was not doing this previously I think) -
>> Album rating: 5 <<  Repeating the formula of Low's half-vocal/half-instrumental structure, Heroes develops and strengthens the sonic innovations David Bowie and Brian Eno explored on their first collaboration ...
Reply #842
@paregistrase
I'll think about it & see if it can be done neatly. Next version will likely be a hotfix for a few issues that have arisen so maybe sometime in the future.
@anamorphic
Thanks for the report. The issue should be fixed for the next version.
@yeyo
Does this happen with any particular artist?
Please can you provide an example artist that it occurs with. Also which language is being used. If it's not English, is "Fallback to English Server" enabled?
So far I haven't been able to reproduce the issue, so please provide the exact steps to replicate the issue.
Reply #843
@paregistrase
If it can be done elegantly, it will be a cool feature. But if it is problematic or break other stuff, don't bother too much about it. It can be done with a script to replace genre values.
Reply #844
@yeyo
I have now managed to reproduce the issue & added a fix (missing reset) for the next version.
Reply #846
New Version: Biography v1.3.3
Such an essential panel for FB! Many thanks and rock solid work.
If you're considering future dev ideas, displaying TF code (as alternate option to lyrics/textreader) would be amazing.
foo_textdisplay is so WIN95 compared with what you've built. ;)
Reply #847
On the Requirements page it says spider monkey panel 1.5.2+.
Which version are you using for your testing... and basically do you recommend using the lastest v1.6.1, stay on v1.5.2... or it doesn't matter either way.
Reply #848
Thank you WilB for Biography! It's one-of-a-kind!
Looks so good and works so well with foobar 1.6.11 and DarkOne4 theme!
Much appreciated!
I use Spider Monkey Panel v1.6.1 by TheQwertiest.
What is the opposite of music?
Reply #849
Haven't updated in years, until yesterday. Some awesome new features!
I've added 2 panels, one with library tree and another one with artist pics grid - and I can't open the settings window for one of them anymore - it says check console, there I see Library Tree: options dialog isn't available with current operating system. All settings in options are available in panel properties. Common settings are on the menu.
Why so?
