@Defender
Arrow Rock Radio
Try inserting the following in the advanced radio stream parser located in foo_spider_monkey_panel\package_data\{BA9557CE-7B4B-4E0E-9373-99F511E81252}
This should work with default title format settings (options > server settings... > title format)
case 'https://stream.arrowrockradio.com/arrowrockradio':
// artist needs stream name removing
artist = $.eval('[$trim($replace(' + (typeof cfg !== 'undefined' ? cfg.tf.artist : ppt.tfArtist) + ',Arrow Rock Radio:,))]', focus, ignoreLock);
//console.log('artist', artist);
// title is correct except it's uppercase: including here means it goes through the titlecase converter
title = (item || '').trim();
//console.log('title', title);
break;
Filmstrip display setting should be retained & I can't reproduce what you're seeing. Please provide exact steps to reproduce. Unlikely possibilities are a bad foobar2000 shutdown or theme file set to read only.
