@kahel
Is there a way to disable image loading?
You can middle click the text or use the menu to go to text only. At least see if that solves the issue. In my tests the behaviour seemed OK as is with images on. Do you have anything else loaded which would cause an issue?
If the current middle click method is insufficient, when would you change a setting if added?
Lastly it's possible to adjust the timing of the events. Go to panel.js and locate the following two functions ~lines 192 to 204
this.focusLoad = $.debounce(() => {
if (!ppt.img_only) txt.on_playback_new_track();
if (!ppt.text_only || ui.style.isBlur || ppt.showFilmStrip) img.on_playback_new_track();
}, 250, {
'leading': true,
'trailing': true
this.focusServer = $.debounce(() => {
this.changed();
}, 5000, {
'leading': true,
'trailing': true
change them to
}, 1000, {
//'leading': true,
'trailing': true
this.changed();
}, 5000, {
//'leading': true,
'trailing': true
You can also try adjusting the 1000 value (1000msec is 1 second delay)
If that's useful, I can add some advanced options.
@makrobes
This seems like a question you asked here.
You can try putting the following in options > server settings > title format > %BIO_ARTIST%:
$puts(str, feat. )$puts(len,$len($get(str)))$puts(pos,$strstr($lower(%artist%),$get(str)))$cut(%artist%,$sub($get(pos),1))
@Fizbin
Default behaviour is to show the filmstrip images provided there is greater than one, which normally there would be in artist view. May be one of the settings is wrong.
Simplest solution is to go to options > panel settings tab > click reset all panel settings. Ensure you have backed-up panel properties before doing this if you've made changes you want to keep.
If that doesn't work go to options > server settings tab > reset all server settings.
You can check if images are in the download folder. You can also try menu > sources > force update
Fresh installs put data and images in the ...spider_monkey_panel\package_data folder\{BA9557CE-7B4B-4E0E-9373-99F511E81252}.
Upgrades retain the original yttm location as outlined by redorb.
