Topic: Biography (Read 79370 times) previous topic - next topic
Re: Biography
New Version: JScript Biography 0.9
REQUIREMENT: JScript panel 2.01+
Existing users: If updating from v0.8.5.1 or v0.8.5.2, you just need to install v0.9. If updating from v0.8 to v0.8.5, to retain settings, install 0.8.5.2 first and before updating JScript Panel to v2+.
Re: Biography
New Version: JScript Biography 0.9.0.3
This is maintenance update to fix compatibility with JScript Panel 2.2.0+. There are no new features.
Re: Biography
New Version: Biography 1.1.1
REQUIREMENT: Spider Monkey Panel 1.2.1+
Optional: FontAwesome. This font is highly recommended for better rendering of certain buttons. If not installed, affected buttons fallback to a different style.
Please post discussion here.
Re: Biography
Reply #33
New Version for JScript Panel: Biography 0.9.0.4
REQUIREMENT: JScript Panel 2.2.2+
This version is intended for users who wish to continue using JScript panel. There are no new features compared with earlier 0.9.x.x versions. It's recommended that you use the latest Spider Monkey Panel version if possible, e.g., it has a newer feature set and is more actively maintained.
CHANGELOG v0.9.0.4
CHG: Renamed server settings ini file to biography_jsp.ini to avoid potential conflict with the spider monkey panel version. This will reset server settings.
FIX: Compatibility with JScript panel 2.2.2+.
FIX: Updated due to changes at lfm.
Re: Biography
Reply #34
Yep. But please put all comments and discussion in the main thread (as linked above). This is to keep this thread free of clutter, so latest download links can easily be found.
Re: Biography
Reply #35
New Version for JScript Panel: Biography 0.9.0.5[/b]
REQUIREMENT: JScript Panel 2.3.1+
This is a maintenance update intended for users who wish to continue using a JScript Panel version. There are no new features compared with earlier 0.9.x.x versions. It's recommended that you use the latest Spider Monkey Panel version if at all possible, e.g. it has a newer feature set and is more actively developed.
CHANGELOG
Compatibility fix for JScript panel 2.3.x series
Re: Biography
Reply #36
New Version: Biography 1.1.2
    Highly recommended for better rendering of certain buttons. If not installed, affected buttons fallback to a different style.
Re: Biography
Reply #37
New Version: Biography 1.1.3
REQUIREMENT: Spider Monkey Panel 1.2.2+
Optional: FontAwesome: Highly recommended for better rendering of certain buttons. If not installed, affected buttons fallback to a different style.
Re: Biography
Reply #38
REQUIREMENTS:
Spider Monkey Panel 1.4.1+
IE9 or later
FontAwesome
INSTALLATION
IMPORTANT: If updating from v1.1.3, and you wish to retain panel settings, export panel properties before installing the new version. Import them after installation. The new version no longer uses biography.ini. It's left in place for back compatibility with v1.1.3, otherwise it can be deleted. Settings therein are automatically imported into the new version.
This version has to be installed as a package.
1) Add a spider monkey panel to foobar2000.
1) Right click the spider monkey panel while pressing the windows key + shift. Choose configure panel.
2) On the script tab choose package.
3) Click the import button and import the biography package.
Troubleshooting
Please note that the package manager is a new feature of spider monkey panel. If you experience issues with the spider monkey panel installer follow the guide below:
Spoiler (click to show/hide)
Re: Biography
Reply #39
Biography v1.2.0-Beta.2
Requirements: see previous post
INSTALLATION
New install or update from v1.1.3 or earlier versions of biography
Follow the installation guide in the previous post.
Update from v1.2.0-Beta.1
Unzip Biography 1.2.0-Beta.2
Close foobar2000
Navigate to the packages folder: foo_spider_monkey_panel\packages\{BA9557CE-7B4B-4E0E-9373-99F511E81252}
It should either be directly in your foobar2000 profile folder or in a subfolder within called profile.
Replace the contents with the new version, i.e. replace the assets folder, the scripts folder & 3 files with the new ones.
Re: Biography
Reply #40
New Version: Biography v1.2.0
REQUIREMENTS:
Spider Monkey Panel 1.5.0+
IE9 or later
FontAwesome
INSTALLATION
If UPDATING consider exporting panel properties to back-up settings (right click the panel while pressing the windows key + shift)
    - REQUIRED if updating from v1.1.3* or earlier & you wish to retain panel settings. Import them after installation.
    - OPTIONAL if updating a package, as settings should automatically be retained. Recommended as good practice, if you've done significant customization, in case the unexpected happens.
New install or update:
1) Add a spider monkey panel to foobar2000 if required
2) Close any instances of windows explorer using foobar2000 folders or subfolders
3) Right click the spider monkey panel while pressing the windows key + shift
4) Choose configure panel
5) On the script tab ensure package is selected
6) Open package manager if it doesn't open automatically
7) Import the package
*biography.ini is no longer used. It's left in place for back compatibility with v1.1.3, otherwise it can be deleted. Server settings therein are automatically imported into the new version.
