Topic: lame3995o (Read 18842 times) previous topic - next topic
Re: lame3995o
Reply #50
I gave the updated link in reply #36.
I'll try to have the mods let me update my original post.
It's a pity that different development environtments lead to different encoders. I was troubled by this when I started doing Lame development. The then active Lame developer, robert (haven't heard of him for years unfortunately), helped me a lot doing my first compilations (I wasn't used to C programming environments). He used VC++, and so did I. First thing I noticed was that using the original Lame source the VC++ compiled encoder produced other results than the Rarewares encoder which used the same source. I computed the difference signal, and the difference wasn't even very small. robert convinced me that I don't have to care.
As long as you don't have any evidence for audible differences I think you don't have to worry. And if you do want to use exactly the encoder I tested just use my exe.
lame3995o -Q1.7
opus --bitrate 140
Re: lame3995o
Reply #51
Thank you.
I've noticed that files encoded with your lame3995o have a higher lowpass. Or no lowpass at all?
Here's my encoding settings. And the same file that was encoded with your old lame3100m. Click on thumbnails to enlarge.
Is this normal? I think the lowpass value of 22.1 kHz (-Q0) is not good.
Re: lame3995o
Reply #52
With lame3995o and each -Q level there is an underlying basic -V level. The encoding parameters of my machinery have a value at least that of this basic -V level. This goes also for the lowpass value (though not really a quality parameter).
The basic -V level for -Q0 is -V0, so -Q0 uses the lowpass value of original Lame's -V0. I have no reason not to trust in original Lame's lowpass value (though it's true I was more conservative with former versions of my variant).
If you prefer another lowpass just use the lowpass option.
lame3995o -Q1.7
opus --bitrate 140
Re: lame3995o
Reply #53
Thank you again.
What do you think? Is it still okay to use lame3100m? Because I'm quite satisfied with quality it produces.
Also I think having lowpass at 18.2 kHz will result in more data in bit reservoir, thus making overall better sound quality than 3995o with no lowpass at all (-Q0). Correct me if I wrong.
The MP3 format has difficulty storing content above 16 KHz without sacrificing quality and increasing the bitrate requirements of the lower frequency bands.
So, the lowpass at 22.1 kHz (3995o -Q0) is an overkill. We cannot hear such high frequencies, anyway.
The MP3 format has a technical limitation that forces a trade-off: the more accurately the highest frequency band (16 KHz and up, normally) is encoded, the greater the space required to encode the lower frequency bands with similar quality. In other words, if the highest frequencies are preserved well, the quality of the much-more audible lower frequencies is sacrificed, and the bitrate has to be increased significantly to compensate, and it might not always be possible to fully compensate because of the 320 kbps limit on bitrate.
Re: lame3995o
Reply #54
About lame 3.100...
From  URL
I think the main issue is that after the 3.99.5 release the main SVN
branch (trunk) has been (mis-)used a a feature branch for some
improvements to the psycho-acoustic model. However, these improvements
never really took off, the changes were rather considered as
regressions and after the main developer lost time (and/ot interest?),
nobody really dared to touch that code.
Then came the first patches and fixes addressed at the 3.99.5 release
and were applied on top of the current development state, but nobody
dared to do the overdue point release because of all the other changes
to the code [1]. As such, the code wasn't touched at all anymore,
because it couldn't get released as is and no preparations were ever
made to do a point release with minimal changes to the previous one.
This is at least how I perceived what has happened. However, this
doesn't mean that it really was like this.
Said that, that talk has spuried some changes (security related mostly) that are being done over 3.100.
Re: lame3995o
Reply #55
IMO lame3995n was a major step forward compared to former versions (and lame3995o is different only for -Q values of 1 or similar).
However as you use the highest VBR bitrate setting this probably doesn't mean any audible difference.
But if it is only the lowpass you care about maybe I can bring some relief to you by mentioning that Lame3.99.5 (original as well as my variants) demands only for a very limited precision in the 16+ kHz range compared to the more audible ranges. I guess that's why the lowpass value is that high when using -V0. So it can't happen that a lot of bits are 'wasted' eventually.
But there's also no reason not to simply use the --lowpass 18.2 switch in case you prefer this.
If you care a lot about the bit reservoir it may be wiser to use a somewhat lower -Q value like -Q1 or similar. I use -Q1, but after having tried opus I would even go lower. With opus as well as lame3995o it is only harpsichord music which requires an (otherwise inadequate) very high bitrate setting. Everything else is perfectly encoded when using lame3995o -Q1.7, and there is even a certain safety margin with this. I do not struggle any more for a general encoder setting which gives perfect results for any kind of music. I can easily do so as harpsichord music isn't exactly my favorite genre. Moreover even the worst harpsichord sample I know is well acceptable when using -Q1.7, and I guess -Q1.7 is perfect for many a harpsichord music. And I can always use -Q0 for the few tracks with dominating harpsichord music I have. I don't have a reason to reencode my collection, but if I had to I'd use -Q1.7 (200 kbps on average for pop music).
lame3995o -Q1.7
opus --bitrate 140
Re: lame3995o
Reply #56
I  was allowed to update the link to lame3995o in the OP.
Done.
lame3995o -Q1.7
opus --bitrate 140
Re: lame3995o
Reply #57
I downloaded an installed lame3995o only for Norton to automatically delete it as it was apparently a risk. Has anyone else had such a problem?
Many thanks
Re: lame3995o
Reply #58
I'm sorry you have this problem.
I have no idea why Norton behaves like this. I just had virustotal check lame3995o online using 64 antivirus tools and none of these had a complaint. Norton unfortunately is not among these 64 tools.
lame3995o -Q1.7
opus --bitrate 140
Re: lame3995o
Reply #59
Strangely, on VirusTotal, Symantec says it's clean. Submit a false positive to them?
Re: lame3995o
Reply #60
I gave up using Norton many years ago because of frequent false positive issues.
John
Re: lame3995o
Reply #61
Now a (stable) Lame 3.100 has been released, would it make sence to create a new lame3100x ? (just backport the fixes of LAME3.100 I guess).
BTW AFAIK there were no quality changes, but some security and buffer issues.
Re: lame3995o
Reply #62
ATM I have very serious health problems.
So this may be a question to me later next year.
lame3995o -Q1.7
opus --bitrate 140
Re: lame3995o
Reply #63
Sorry to hear that. May I wish you a speedy and full recovery.
John
Re: lame3995o
Reply #65
Thanks a lot.
lame3995o -Q1.7
opus --bitrate 140
Re: lame3995o
Reply #66
Get well soon. Wishing you a speedy recovery!
SimplePortal 1.0.0 RC1 © 2008-2018
