Topic: foobar2000 vs HDD clicking (Hard Drive Head Parking every 8 seconds) (Read 5309 times) previous topic - next topic
Hello, when playing music through foobar2000, there is the problem of hard drive head parking during the transition between tracks, that are very well seen in the screenshot. This causes the characteristic clicks sound and delays (which is very annoying when manually switching tracks). There is, apparently, due to the buffering of each of the next track, and, this also applies to image albums (File+Cue). To solve this problem, you need to read from disk is not interrupted for more than 5 seconds, because parks the hard drive heads after 7-8 seconds of inactivity.
Modern capacious the HDD, very frequent auto-parking has become the standard of today, and millions of PCs. Not so long ago Piotr Pawlowski added a very useful option "Prevent hard disk sleep while playing", may be, possible to add the option against the auto-parking clicking, which does not allow to enjoy music. :'(
Thank you in advance for your attention to this matter!
p.s.
Sorry for my bad english.
p.p.s
wdidle3 & hdparm not working :(
http://i.imgur.com/wKO5sVr.png
Re: foobar2000 vs HDD clicking (Hard Drive Head Parking every 8 seconds)
Did you try to increase buffer length? File->Preferences->Playback->Output->Buffer length
Did you try to increase buffer length? File->Preferences->Playback output->Buffer length
I use 0 kB, but i tried, it does not help. I use foo_ramdisk.dll, it works (Thank You Piotr!), but not very convenient.
Shut off power management for your drives? I don't understand how it's timing out and shutting the drives off during the mere milliseconds that it takes to close one track and open another.
Power management does not help, it is responsible for this hdd firmware. Search in Google: "wd green head parking problem" or "load unload cycle count seagate". Almost all modern capacious hdd have this.
https://www.reddit.com/r/techsupport/comments/41ip2j/western_digital_caviar_blue_head_parking_pc_freeze/
I was talking about File->Preferences->Playback->Output->Buffer length, not File->Preferences->Advanced->Playback->Full file buffering up to.
I'm sorry, i completely forgot about this option. Set 50 ms and i'll be testing more in detail. :)
I set 50 ms and watching in the task manager, on one album (File+Cue) was constant read speed 131KB / s and !!! no clicks !!! , but all the other albums (File+Cue) on the read speed of 524 KB / s, and the clicks are present. Set 30000 ms and clicks occur more often. :-\
Further evidence that spinning rust is no longer a trustworthy storage medium. From now on, I'll be expanding my storage entirely with 1TB or larger SSDs, as I need them.
This old WD Blue and pair of Reds will have to do for now, although I don't expect my storage needs to ever exceed this current capacity any time soon. I wasn't even halfway into the one 4TB I had, and I needed another 4TB to move the data off it so I could reformat it with a different partition format.
Until they decide to start pulling similar stuff with solid state media.  I swear they do this stuff intentionally to force people off one kind of media and on to another by making the other look more unreliable than it really is.  Even if the new media is more reliable than the old media there's money to be made.  Hard drives are not obsolete but many of them are also solid state manufacturers and would love to speed it's demise on something that probably won't be as profitable to them in the future then make the solid states fail after a certain timer that ticks down on newer solid states and fries up the chips intentionally when something else comes along or they're not making as much money as they used to.  Think about the limited write cycles solid state media has.  They love to have some big money from filmmakers that tons of editing that's for sure by forcing them on to it.
Planned obsolescence.
But ssd is fantastically expensive and erases the information if they do not use for a long time. Hdd more reliable for music storages or backups, but clicking sound each switching songs can be very annoying. ::)
Frequent auto-parking, it's not only planned obsolescence, this is very useful for laptops, but not for desktops (exceptions are seismic dangerous places).
How long exactly?  Heat does have an effect on that.  It's usually more worn out drives that do it, too.  Having a back up of a back up is not a bad idea either and most things do eventually come down in price (cost of manufacturing).  Although some things actually go up in price (supply and demand).  I'm still using optical media for back up.  :)  They certainly don't make optical media like they used to.
The Pacific ring of fire comes to mine actually.  Californians most love their solid states if they can afford them and I'm sure the Japanese have done away completely with hard drives.  :P
Refer to the table, it all depends on the recording conditions and the storage conditions. But preferably not more than six months without electricity. Over time, the transistor is discharged and the information is lost.
Optical media is a good thing, one 3TB HDD = 580 DVDs. :)
We must ask the Japanese. :)
http://i.imgur.com/VmIZBI9.png
Turn up the volume, problem solved.
Serious solutions would be streaming from a server/NAS in another room or solid state drives as already suggested.
it does not help much when listening Chopin. :) (youtu.be/ef-4Bv5Ng0w)
It is too expensive for me. ::) In addition to store music on a SSD is very unreliable.
Maybe replace the drive with a different brand and use Mr click-a-lot as a external backup drive?
http://www.pcworld.com/article/2925173/debunked-your-ssd-wont-lose-data-if-left-unplugged-after-all.html
That table you reference only applies to SSDs that reach EoL.
You could try to change the enclosure with another one , to isolate the noise.
Or you could use a script , only when foobar2000 runs , to read or write some file to disk every 5secs to block/avoid parking.
By all means always clone (sync) a hd drive with another hd drive (backup) , because one day it WILL FAIL.
Just pray they don't fail at the same time.
A_Man_Eating_Duck
WD, Hitachi, Seagate they all have this. And i have 5 Mr. click-a-lot. :)
But transistors is discharged and hard drive discs can store data for up to 10-20 years. :o
zeremy
I tried, but nothing happened.
I don't know how to program, :( and I would love to have this functionality in the foobar2000 as the same option "Prevent hard disk sleep while playing".
So you would only listen to music once every 6 months? Also Mechanical drives do fail when they want as well. 10-20 years is a bit of a reach though, I'm sure the interface alone would be render the drive obsolete well before 20 years.
I don't think the drive is at fault, it's the external enclosure.
Put your music files on an SSD, with backups on a mechanical drive. If the SSD fails, copy your backup files to a new one.
Mind you, you'll have to write an enormous amount of data to the SSD before it goes kaput. Like petabyte enormous. But you'll rest easier knowing your files are backed up to HD.
Can you try this simple batch file to see if there is any difference.
Replace C:\antipark.txt with the drive letter you want to  e.g E:\antipark.txt ( edit the attached file with notepad)
Run the batch file first ( it will open in a cmd window) and play something in foobar from the drive.
@echo off
:loop
echo %date% %time% >> C:\antipark.txt
timeout /t 5
goto loop
lol, "spinning rust" :)  never looked at it that way haha.
Wild thought. Use your preferred defragger? to keep the drive busy while playing music?
