Topic: Can remastered CDs sound too different and modernized? (Read 17712 times) previous topic - next topic
Re: Can remastered CDs sound too different and modernized?
some albums labeled as "FDR" (that's full dynamic range), when they were previously released only with a lot of compression:
Carcass — Swansong
At the Gates — Slaughter of the Soul
(for all of the above I ignored releases on non-digital mediums, of course)
Earache's "full dynamic range" series, well ... not all have higher DR. I have not scrutinized it, but I found that both Bandcamp downloads of Sleep's Holy Mountain have a DR of 13, which is the same as my 1992 CD.
So they have a "full dynamic range" remaster with no higher dynamic range ...
That's why I added "when they were previously released only with a lot of compression".
Of course some of them had no problem to begin with.
Carcass — Swansong
That is the wrong part. Even at least one that was previously released with the same dynamic range now is for sale in two editions from the same outlet: a DR 13 edition, and a "full dynamic range" with a DR of ... 13.
I would make the hunch that they just went back to all their files and did a "flat" transfer without any limiting, and without checking whether the "other" had any such processing, but arguably it looks a bit like audiophoolery.
That's specifically what I am excluding.
I were talking about the albums which were previously NOT available with the same DR.
I did not deny that a part of these series are nothing new, but some are something new.
Or at least I could not find any mentions on the Web that these 2 albums
Carcass — Swansong
were already available in full DR before they were re-released with "FDR" mark. (If I search these two on the DR database, there aren't any normal versions before "FDR").
If you read it carefully I never explicitly mentioned other releases under "FDR" mark as being an improvement — indeed some of them are nothing new.
…without checking whether the "other" had any such processing
By the way, it's quite easy for the albums released before 1993: nobody was doing such extreme DR compression before that year. So, for example, I can tell even without listening/looking that "FDR" re-release of https://en.wikipedia.org/wiki/Altars_of_Madness was pointless.
