Topic: dither (Read 3184 times) previous topic - next topic
Re: dither
Noise shaping was preferred with the poor quality 16 bit converters of the past, but with modern converters it's not really necessary. A lot of professional audio engineers now stick with TPDF, for the aforementioned reason, as well as for the fact that if any further processing is done to a lossless file (including encoding to a lossy format, or even a gain change), the effects of noise shaped dither will be completely irrelevant and could lead to audible distortion. With no shaping/TPDF it's less of a problem.
If you really wanna get your head around dither, then I can highly recommend Ken Pohlmann's book, "The Principles of Digital Audio". If you read, absorb and understand that, you'll be in a much better position to discuss it.
Re: dither
Alright, maybe I am not as advanced audiophile as the others here, so my posts could be searching for knowledge rather than proving it.
Hydrogenaudio is full of knowledge. Do search more, there is much to find.
Anyway I tried the SoX command line program and find its dither options promising.
Also it is discussed (http://www.audiocheck.net/audiotests_aliasing.php) that some cheaper (but common) sound card can exhibit playback aliasing at upper range frequencies which can compromise the statement about not hearing the shaped filters, since it can manifest as different sound/distortion in lower range.
Now that you became an expert please explain how aliasing makes shaped dither more audible? Samples welcome.
If anybody experienced can discuss e.g. TPDF, TPDF shaped, modified-e-weighted, low-shibata etc. it could be probably beneficial.
Been there, done that. Even posted about my findings and i use low-shibata, others may like others more.
Please tell us how all the above shapes sound to you, offer samples and where it is problematic and audible, come back when you've done that and surprise us.
I really like to have a harder #TOS8 enforcement because many noobs palaver around to much.
Re: dither
Modern converters are better than 20bit these day easily it seems. So in that case no one shapes.
In the case here we talk about foobar using shaped dither when going to 16bit from HiBit content.
We can leave out if lossy encoding wastes bandwith for representing the dither.
