Topic: help building flac (Read 3976 times) previous topic - next topic
help building flac
i have not done this before, so i am not sure if everything went fine while building flac under mint.
what i have done actually is:
downloaded and unpacked latest tar.xz
make sure autoconf and libtool are installed for building
open up a terminal and enter: ./configure
>>> a config summary showed up
next i entered: make
in the terminal the compiling process started, which took about one minute
now if i understood correctly, freshly created flac & metaflac compiles should be found in /scr/flac subfolder, but that is not the fact.
am i missing a step?
Re: help building flac
sudo make install
...provided there were no error during compiling.
TAPE LOADING ERROR
hm, so these 2 files (flac, metaflac) are only created after installing?
no chance to check them out in first place (after the make-process)?
No, the flac and meteflac binaries should be created during the make.  metaflac itself would be in src/metaflac/.libs.  .libs is a standard build location for object and binary files.  You can execute a binary directly from there, or from anywhere really, but often you will use make install to move all your binaries and objects to standard system locations.  make install will take care of setting up any associated library objects in the right locations, which is usually necessary, although you might already have libFLAC installed or you might have compiled a static binary that doesn't require libraries.
P.S.  That applies to Linux, but you may be in Windows?  I think everything goes into src/metaflac/objs on Windows.
it is all there, ha!
i did not look for hidden .libs folders, that's all. thank you so much.
but now i am facing another problem. when running the 1.3.1 flac binary i get this terminal output:
flac - Command-line FLAC encoder/decoder version 1.3.0
Copyright (C) 2000-2009  Josh Coalson
Copyright (C) 2011-2014  Xiph.Org Foundation
downloaded from here: downloads.xiph.org/releases/flac/flac-1.3.1.tar.xz
any ideas?
@sanskrit44 : To launch a locally build file on linux, you need to explicitely say so.
I.e. : you either need to append ./ , or use the full path:
$> ./mylocalexe
$> /users/mine/builds/mylocal/mylocalexe
Also, depending on how you build it, your build might still use the library installed on your system instead of the one located in the build dir.
IIRC, that can be solved setting the LD_LIBRARY_PATH, but It's been a long time since I've done any serious building on linux to be exact on that
@jaz: sure, i know. of course i ran ./flac in binary folder.
You are executing the wrong binary.
which flac # will search in $PATH, typically /usr/local/bin, /usr/bin ... make install usually installs into /usr/local if you didn't change ./configure --prefix ...
which ./flac # in the directory where the compiled binary is
should show different output.
"I hear it when I see it."
@xnor: i did not make install
just to be sure i entered in terminal (where my new bin is located):
/home/my-user-name/flac-1.3.1/flac
perhaps someone can confirm this?
As [JAZ] wrote, "depending on how you build it, your build might still use the library installed on your system instead of the one located in the build dir".
@lvqcl: ok, i see. but i followed the standard process in flacs readme, no extra options are taken (at least something that important should be explained in detail on top).
maybe you are willing to do a quick test compile and proof me wrong?
see:
merci
But the standard process assumes that you make install and that you don't already have an old version installed...
from the README file:
FLAC uses autoconf and libtool for configuring and building.
Better documentation for these will be forthcoming, but in
general, this should work:
./configure && make && make check && make install
The 'make check' step is optional
(emphasis is mine).
On Jessie with ./configure && make I get;
src/flac/flac
which says
(And there is also flac installed from repos which says 1.3.0)
p.s. On Arch, flac says 1.3.1 so I don't configure/make :P
If you have existing flac libraries installed and you don't want to do make install (which would overwrite them), you might find it simpler to build a static binary.  The binary will be bigger, but you won't have to worry about configuring which libraries it is going to use.  You can do this with an option to configure.
thank you for letting me know. when you can compile with 1.3.0 installed and did not select any extra options, i should be able to do that under mint as well, i guess.
this is my config summary. i am not sure if the 1.3.1 version already implies a final 1.3.1 build as well?
Configuration summary :
    FLAC version : ........................ 1.3.1
    Host CPU : ............................ x86_64
    Host Vendor : ......................... unknown
    Host OS : ............................. linux-gnu
    Compiler is GCC : ..................... yes
    GCC version : ......................... 4.8
    Compiler is Clang : ................... no
    SSE optimizations : ................... yes
    Asm optimizations : ................... yes
    Ogg/FLAC support : .................... no
besides: it is getting even more bizarre - i have downloaded this compile for mint for testing purpose, unpacked it and executed the flac bin. again i see 1.3.0? installing it makes no difference at all.
@lithopsian: well, that would be an option, unless someone is willing to show me how to do this in detail ;)
Most packages are compiled with shared libraries.
That means that there is an executable (flac) and a library (libflac). Distributions even split those, so that you don't need to install the flac package when some application just depends on libflac. So even if you uninstall flac it could leave a libflac package behind.
Now, running the executable will try to load the shared library in the default places (usually /lib and /usr/lib) if you didn't specify LD_LIBRARY_PATH.
So whatever executable you run, as long as it is compatible, it will typically load the installed system libFLAC.so.whatever-version.
So the easiest would be to set LD_LIBRARY_PATH to wherever your new complied library is.
sudo aptitude install flac
dpkg -l "*flac*"
Output:
||/ Name                          Version             Architecture        Description
ii  flac                          1.3.0-3             amd64               Free Lossless Audio Codec - command line tools
ii  libflac8:amd64                1.3.0-3             amd64               Free Lossless Audio Codec - runtime C library
wget "http://downloads.xiph.org/releases/flac/flac-1.3.1.tar.xz"
tar xf flac-1.3.1.tar.xz
cd flac-1.3.1/
./configure && make
flac -v # ==> flac 1.3.0
src/flac/.libs/flac -v # ==> flac 1.3.0
# lets check what is going on:
ldd src/flac/.libs/flac # as expected ==> libFLAC.so.8 => /usr/lib/x86_64-linux-gnu/libFLAC.so.8 (0x00007fce4ffc6000)
# now we want it to load our freshly complied library instead
LD_LIBRARY_PATH=src/libFLAC/.libs/ src/flac/.libs/flac -v # ==> flac 1.3.1
# check
LD_LIBRARY_PATH=src/libFLAC/.libs/ ldd src/flac/.libs/flac # ==> libFLAC.so.8 => src/libFLAC/.libs/libFLAC.so.8 (0x00007fc1fa598000)
And we can also install:
sudo make install # installs to /usr/local by default
flac -v # ===> flac 1.3.0
sudo ldconfig # update shared library cache. this will only work if your ld.conf somewhere includes /usr/local/lib
flac -v # ===> flac 1.3.1
If you have a debian system then simply grab the latest source package, build it which should result in two .debs and install both with dpkg -i "*flac*.deb".
