Topic: M3u8 and foobar crashed (Read 2484 times) previous topic - next topic
Hi to all, when i play this m3u8 file (web radio) foobar crashes, vlc instead work correctly, where is a problem?
Web radio m3u8:
http://radiom2o-lh.akamaihd.net/i/RadioM2o_Live_1@42518/index_48_a-b.m3u8?sd=10&rebase=on
I need a plugin for foobar to play m3u8 playlist?
Can i modified this m3u8 to m3u for foobar?
Re: M3u8 and foobar crashed
foobar can't play HLS yet:
https://hydrogenaud.io/index.php/topic,105603.0.html
https://hydrogenaud.io/index.php/topic,107507.0.html
https://hydrogenaud.io/index.php/topic,108403.0.html
https://hydrogenaud.io/index.php/topic,108657.0.html
Some other players can do it: VLC (version 3.0 beta to avoid the high CPU usage of v2.2), MPC-HC and players using BASS with this beta plugin: http://www.un4seen.com/forum/?topic=16905.0 (Works with AIMP3).
ffplay can play HLS streams, so considering foobar is now based on ffmpeg I guess, and hope, it shouldn't be a problem for foobar to also play HLS streams soon.
the problem is HLS not m3u8..
Then i have no possibility to play this radio?
There is not other link for play it in" standard streming"?
The link you have posted is using segmented adaptive streaming which is often called HLS while it can be DASH or HDS or MSSS.
As of today foobar2000 can't play segmented streaming. Read my post again for other solutions.
What about you check the website of the radio ?
I had a quick look at the radio website and I couldn't find any other 'classic' stream.
thanks for you work..
