Topic: Library Tree (Read 70631 times) previous topic - next topic
Re: Library Tree
All users of Library Tree 1.3.9.2 should ensure that the 'Chakra' script engine is used (requires IE9 or later) - select in the JScript panel configuration window  (shift + right click). The script will not run properly with the JScript engine.
Re: Library Tree
New Version: Library Tree 1.4
Requirement: JScript Panel 2.1.0+
Use the 'Chakra' script engine if possible (requires IE9 or later) - its faster with this script. Set in the JScript panel configuration window (shift + right click).
Re: Library Tree
New Version: Library Tree 1.401
Requirement as above
Re: Library Tree
New Version: Library Tree 1.4.0.2
Requirement as reply #48.
Re: Library Tree
New Version: Library Tree 1.4.0.3
This is maintenance update to fix compatibility with JScript Panel 2.2.0+. There are no new features.
Re: Library Tree
Reply #34
New Version: Library Tree 2.1.1
Requirements are as above.
Please post discussion here.
Re: Library Tree
Reply #36
New Version for JScript Panel: Library Tree 1.4.0.4
REQUIREMENT: JScript Panel 2.3.1+
This is a maintenance update intended for users who wish to continue using a JScript Panel version. There are no new features compared with earlier 1.4.x.x versions. It's recommended that you use the latest Spider Monkey Panel version if at all possible, e.g. it has a newer feature set and is more actively developed.
CHANGELOG
Compatibility fix for JScript panel 2.3.x series
Re: Library Tree
Reply #38
REQUIREMENTS:
Spider Monkey Panel 1.4.1+
IE8 or later
FontAwesome
INSTALLATION
IMPORTANT: If updating from v2.1.3, and you wish to retain settings, export panel properties before installing the new version. Import them after installation.
This version has to be installed as a package.
1) Add a spider monkey panel to foobar2000.
1) Right click the spider monkey panel while pressing the windows key + shift. Choose configure panel.
2) On the script tab choose package.
3) Click the import button and import the library tree package.
Troubleshooting
Please note that the package manager is a new feature of spider monkey panel. If you experience issues with the spider monkey panel installer follow the guide in the spoiler here. If you wish to do a manual install as in the guide, just change the master folder to {E85C9EF0-778B-46DD-AF20-F4BE831360DD}
Re: Library Tree
Reply #39
^ moved to correct location in main discussion thread
Re: Library Tree
Reply #40
New Version: Library Tree v2.2.0
REQUIREMENTS:
Spider Monkey Panel 1.5.0+
IE8 or later
FontAwesome
INSTALLATION
If UPDATING consider exporting panel properties to back-up settings (right click the panel while pressing the windows key + shift)
    - REQUIRED if updating from v2.1.3 or earlier & you wish to retain panel settings. Import them after installation.
    - OPTIONAL if updating a package, as settings should automatically be retained. Recommended as good practice, if you've done significant customization, in case the unexpected happens.
New install or update:
1) Add a spider monkey panel to foobar2000 if required
2) Close any instances of windows explorer using foobar2000 folders or subfolders
3) Right click the spider monkey panel while pressing the windows key + shift
4) Choose configure panel
5) On the script tab ensure package is selected
6) Open package manager if it doesn't open automatically
7) Import the package
