Topic: Party Shuffle (Read 1810 times) previous topic - next topic
Party Shuffle
Party Shuffle
A simple plugin which adds Party Shuffle mode to foobar2000 (like iTunes and Android Music Player have).
Usage
There is a menu item Playback Party Shuffle to turn on/off the feature.
If this feature is turned on then random tracks from the media library will be added to the current playlist when the last track has just finished playing so the next track will continue playing.
If Stop after current is on in this case then only new tracks will be added and a playback will be stopped.
Source code: https://github.com/phts/foo_partyshuffle
Download: https://github.com/phts/foo_partyshuffle/releases
Re: Party Shuffle
Thanks for plugin but... i cant find any version that can handle this plugin....
Not working on foobar2000 version : 1.2.9, 1.3.4, 1.3.6, 1.3.7, 1.3.8, 1.3.9.....
Re: Party Shuffle
Do you still use Windows XP?
Re: Party Shuffle
The lack of responses suggests that no one (other than me) is willing to point out the inconvenient truth that Windows XP is poorly (and at best, reluctantly) supported nowadays, for many good reasons. Your definition of "good enough" will have to be very flexible in the coming years.
Re: Party Shuffle
There's no reason not to support Windows XP in software that doesn't require or even use any fancy features introduced by the newer OSes.
Here's a compile that works with Windows XP and on foobar2000 v1.1 and newer.
Quick note: You need to use playback order "Default" for it to work.
