I guess, ffprobe certainly doesn't seem to bother to display either side or rear metadata (fdk_aac was used for encoding)
./ffprobe /Users/b/Downloads/5.1ch_test_file_rear.flac.mp4
ffprobe version N-76262-g2ccc1b3 Copyright (c) 2007-2015 the FFmpeg developers
built with Apple LLVM version 7.0.0 (clang-700.0.72)
configuration: --prefix=/Volumes/tempdisk/sw --enable-gpl --enable-pthreads --enable-version3 --enable-nonfree --enable-libx264 --enable-runtime-cpudetect --enable-libfdk-aac --cc=clang
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/b/Downloads/5.1ch_test_file_rear.flac.mp4':
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2mp41
encoder : Lavf57.11.100
Duration: 00:00:09.10, start: 0.046440, bitrate: 37 kb/s
Stream #0:0(und): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, 5.1, fltp, 35 kb/s (default)
Metadata:
handler_name : SoundHandler
or more with "ffprobe -select_streams a -show_streams file.mp4"
profile=LC
codec_type=audio
codec_time_base=1/44100
codec_tag_string=mp4a
codec_tag=0x6134706d
sample_fmt=fltp
sample_rate=44100
channels=6
channel_layout=5.1
