Topic: Opus 1.1.1 is out (Read 50576 times) previous topic - next topic
Opus 1.1.1 is out
After much waiting, Opus 1.1.1 is finally here. The main changes are:
  • x86 SSE, SSE2 and SSE4.1 optimizations contributed by Cisco,
  • MIPS optimizations contributed by Imagination Technologies,
  • ARM Neon optimizations contributed by Linaro and ARM,
  • many architecture-independent optimizations,
  • memory footprint reductions, and
  • several minor bug fixes.
The quality of the encoder should be mostly unchanged compare to version 1.1. The code is available from the downloads page at: http://www.opus-codec.org/downloads/ or at: http://downloads.xiph.org/releases/opus/opus-1.1.1.tar.gz
In other news, we're currently working on improving low bit-rate quality (< 48 kb/s) for both speech and music. Stay tuned.
Opus 1.1.1 is out
Good job, guys.
it's reported that  Opus 1.1.1 decoder is even faster than Vorbis on ARM9E
https://www.hydrogenaud.io/forums/index.php...st&p=909049
Opus 1.1.1 beta
Clip Zip in rockbox (ARM9E):
opus111b_128k.opus   490.68% realtime   Decode time - 35.85s   48.91MHz
vorbis_128k.ogg   475.53% realtime   Decode time - 36.99s   50.47MHz
nero_lc_128k.m4a   525.56% realtime   Decode time - 33.48s   45.66MHz
Improving quality at <48 kbps makes perfect sense in my opinion as now Opus has highest quality among available formats at 64-96 kbps and higher bitrates.
Let's us know when there will be a test build.
P.S. 1.1.2(AVX optimizations) and 1.2(quality improvements) are planned too. https://wiki.xiph.org/OpusTodo
Opus 1.1.1 is out
Good job, guys.
Opus 1.1.1 beta
Interesting. Is there any way I could update the decoder on android (building from source or something?). Currently, opus still seems to be using more processing power than vorbis on my Helio X10, resulting in worse battery life.
Opus 1.1.1 is out
Could somebody compile a 32 and 64bit release.
EZ CD Audio Converter
Opus 1.1.1 is out
For those interested in testing, you can follow the exp_lbr_tune branch in the Opus git repository. There only one change so far (which already makes a difference), but there will be more. Please give this branch a try and report any improvements/regressions compared to master or 1.1.1.
Opus 1.1.1 is out
Hi, how good is the integrated opus resampler?
I note everything is resampled to 48kHz so if I preprocess source with external resampler, the resampler of opus is bypassed, right?
Opus 1.1.1 is out
Both 86 and 64 isn't starting for me. The RC releases worked fine.
Win 7 64bit fully updated.
Opus 1.1.1 is out
Is it really safe to resample 44.1 kHz to 48 kHz? I thought it can lead to some mathematical error?
I will think about tomorrow's problem tomorrow
Opus 1.1.1 is out
So what? Opus is not a lossless codec anyway.
Opus 1.1.1 is out
I don't see anything bad that can happen when resampling from 44.1 to 48 or vice versa.
Opus 1.1.1 is out
Well I read somewhere it say resampling from 44.1 kHz to 48 kHz cause rounding error
Opus 1.1.1 is out
I think the point is that such an error in inaudible, particularly relative to other artifacts that could arise when using lossless encoding.
My only concern with the fixed sample rate at 48kHz is that I think the Sansa Fuze plays back 44kHz sources better than 48kHz... but I can't remember where I read that, or if the difference would be audible anyway.
Opus 1.1.1 is out
Good job, guys.
Opus 1.1.1 beta
That is actually synced to a Jan 2014 version of libopus, not 1.1.1.
Opus 1.1.1 is out
Wherever you read that, it is not true.
Opus 1.1.1 is out
That upload didn't work as well..
If I run it in command prompt window it writes:
Please verify that both the operating system and the processor support Intel® SSE4_2, MOVBE, POPCNT, F16C, AVX, FMA, BMI, LZCNT and AVX2 instructions.
Opus 1.1.1 is out
I'm running an AMD system. AMD FX-8350 Eight-Core Processor.
Opus 1.1.1 is out
Its compiled with /arch:CORE-AVX2, /QxCORE-AVX2, /QxHost or /fast then.
Opus 1.1.1 is out
Opus-tools win32+win64 binaries
Both 32 & 64bit worked great on my system.
Win7 64 / AMD.
Opus 1.1.1 is out
Tried opusenc from opus-tools v0.1.9-git-aa7e018
Just tested on few clips
At 48kbps , it sounded OK but center imaging sounded mono
At 40kbps, it started to sounded rough
At 32kbps, need a lot of work here.
Ongoing testing
